Thread: Exposed aggregate deck rust stains
    737mech's Avatar
    Jun 2013
    Corinth,TX
    148
    We have about 5 small areas on our newish decking that you can see rust stains. The PB said there is metal bits in the pour.
    They said they could have the pieces chipped out. We are not sure if that will end up looking worse than it all ready is.
    Do you think cleaning the areas and sealing with a quality sealer would be better?
    Our warranty is nearing it's end very soon. I contacted them before Thanksgiving, but we are still waiting for them to fix it.
    Finally completed March 2014
    IG 27,300 gal 35'x16' 3.5'/5.5'/8' diving pool, Pentair Intellichlor IC40, De FNS 60, 3HP Intelliflo VF pump, Easy Touch 4, Kreapy Krauly Platnium, 3/4 Hp booster pump, raised stone wall w/ 2 stone scuppers, Stonescapes aqua blue mini pebble plaster
    Dec 2014
    Houston, Texas
    134
    Re: Exposed aggregate deck rust stains
    My company is a pool builder and unfortunately we too have had this issue. We've tried everything, chipping seemed to be the best. First one we stripped and topped with cool decking but after about 3 months the rust started coming through. Chip method will leave pits but doesn't look bad unless you're looking for it. Just about the same as the rock popping off due to age. Most important thing to do is get it all removed otherwise it'll continue to show up.
