Thread: Extra Lines in post??
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    I have noticed that after i make a post there seems to be quite a bit of blank lines before my sig?
    Is this normal or is there a setting I can change?
    Example: http://www.troublefreepool.com/threa...141#post747141 Edit, i see i didnt need the link as there will be lines after this
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Re: Extra Lines in post??
    The height for a post determined by shorter of the height of the stuff on the left plus the height of the signature, vs the height of the post it's self plus the signature. In this case the height is determined by the avatar plus signature.
    Jun 2014
    Long Island, NY
    340
    Jason
    I got it & Thx for the reply- just trying to save some space
