Thread: My pool looks like ****.....
    Aug 2014
    Shallotte, NC
    693
    ... because the paint is in poor condition. I got a quote of about $4600 to repaint and the estimate included a disclaimer whereby they were not responsible for anything bad happening while the pool was drained. My questions are:
    1) isn't that a lot to pressure wash and paint a pool?
    2) is such a disclaimer acceptable under any circumstances?
    PS
    Amusingly, I used the term Charlie Romeo Alpha Papa, which doesn't look nearly as bad as ****
    38,475
    Re: My pool looks like ****.....
    I highly recommend you save the funds and plan to resurface the pool. Paint seems to last only a couple years before it again looks bad.
    I would say your pool is nearly double the size of the typical residential pool, so that price does not surprise me. You have a lot of surface area.
    There is risk when you drain a concrete pool. But the amount of risk is dependent on how the pool was built (hydrostatic valves?) and your groundwater level. I would think that any reputable pool company would know how to prevent damage while doing the work you hire them for.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,620
    What is said here. The nature of a pool-water, chlorine, etc. means the paint will not last for long at all. Now plaster or such........THAT will last much longer!
    Kim
    Sep 2013
    Dallas-Ft. Worth Metroplex, TX
    810
    Can you show us what it looks like ? :/
    14K Freeform Gunite w/60% Blue Quartz plaster, Quad DE filter, Intelliflo VS Pump + Booster for Cleaner, Aquacal Heat Pump
