View Poll Results: To Speedstir or not
Voters
53. You may not vote on this poll
  • I delegate my sample swirling to a Speedstir
    38 71.70%
  • I swirl my own samples
    15 28.30%
Page 1 of 3 123 LastLast
Results 1 to 20 of 50
Thread: Let's stir up some discussion
    bbrock's Avatar
    Apr 2014
    Livermore, CA
    574
    For some time, I have been tossing around the idea of getting a Taylor 9265 - Magnetic stirrer; better known as the renowned Speedstir. The main time I seem to be wanting it is when I perform the CH test b/c my pool has a relatively high CH (latest CH 1000; just b/c some may wonder what my #s are: pH 7.5, FC 7.5, CC 0, TA 60, CYA 50, temp = 57; my water is balanced per Pool Math and CSI is inline). Thus, I am sitting swirling for some time. Not to mention, occasionally I have lost count of how many drops of reagent I have added, and also had a hard time distinguishing when the water sample color stops changing blue. Thus, sometimes I have added reagent and gotten to my supposed stop point, only to add more reagent and the color continues to change. My thinking is that with a Speedstir, I can more easily focus on the color change vs. managing swirling, counting, and detecting color change.
    If you have a Speedstir, please weigh in here on how you like it and how it has helped you.
    Edit: Sorry about that 0 at the end of samples in the poll. I don't know how to edit the poll and delete that typo.
    Fixed. JasonLion
    19k gal IG plaster, built '70s, probably resurfaced in '80s-'90s; Blue Haven Hayward filter C4520BHMB (Filbur FC-1275 cartridges); Hayward MaxFlo sp2302 VSP 1.5hp; 6 solar panels 288. sq. ft. total (142"x47.5" ea.) on 1 story hm; Pentair Compool LX220 Solar Controller; FlowVis flow meter; Maytronics Dolphin S200; AG 300 gal AquaTerra spa; TF-100 & Speedstir; gone: Pentair Challenger 3/4 HP 1 speed; Polaris 280
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Re: Let's stir up some discussion
    The greatest...
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    I never test without it. SpeedStir fanboy here.
    Isolated Spa - 345 Gallons
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    Speedstir since day one! Makes the mixing consistent.
    J.R.
    20K IG gunnite pool
    2HP Hayward single speed pump
    Cartridge filter
    wjr75's Avatar
    Jun 2013
    IL
    836
    Must have!
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    mikespoolfl's Avatar
    Mar 2011
    Florida
    179
    You mean there's a way to manually mix. Is that like changing channels on the tv without the remote.
    Screen enclosed 17K gal 16x30 IG with Diamond Brite finish, elevated 4 jet spa with spill over, Twin dolphin fountain, Hayward Ecostar pump[ Pentair intelliflo VS, Filter Sta rite Posi-Flo PTM 100, Aqua Cal heat pump, Tiger Shark QC robotic cleaner.
    Stenner peristaltic pump model 45MPHP10, 15 gal storage tank. TF 100 with Speed Stir.
    Dec 2009
    Central Massachusetts
    2,690
    Speed stir
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Oct 2013
    Iowa
    82
    I am a self swirl vote. Since I found this site I don't do the CH test anymore since we have a vinyl pool otherwise I would consider it. That test does take a lot of mixing. I have gotten pretty good at swirling with one hand and dropping with the other for the chlorine test so bothering to get it out to do the test would be more work than testing without it. But if I had to do the CH test regularly I would consider it for that test and I've never tested that with it higher than 120.
    20,000gal in-ground 16x36 sentry pools vinyl liner, Pentair sand filter, Pentair minimax NT heater, auto-cover, Polaris 280 cleaner.
    MARCO...polo's Avatar
    Oct 2014
    East Contra Costa County CA
    102
    CH and salt only. Or on a retest if I've got a result that is real wonky and I suspect it's my count or technique.
    13,000 gal.Peanut shaped IG Plaster (med. gray) w/ 7' raised spa. ALL Pentair: Intelliflow 3hp VS, Cartridge filter, 400,000 btu heater, 2.0hp spa motor, Easy Touch control panel & is4 spa side switch, Intellichlor 40C SWG, Paramount PV3 In Floor cleaning system, spa spillway and two sheer descents. Solar: 10 FAFCO panels 1.5hp booster. Testt kits: K-2006 & K1766 (Chloride/Salt) Fill date August 15, 2114.
    bbrock's Avatar
    Apr 2014
    Livermore, CA
    574
    Quote Originally Posted by mikespoolfl View Post
    That got a great laugh. Tx Mikespoolfl!
    Mar 2007
    San Rafael, CA USA
    12,082
    I swirl manually, but I'm usually only testing pH and chlorine so it's really only the FAS-DPD test where any mixing is done while adding drops. If I needed to test CH regularly, I'd more strongly consider the SpeedStir.
    Jun 2014
    Markham/Ontario
    52
    I like the speed stir because it obviously makes the stirring easier but also because of the built in LED light. I find that I have gotten more consistent results because of the consistent lighting.
    15K Gallons, IG, Vinyl, 1HP Single Speed Pump, Sand, SWG, NG Heater + Solar Panels
    yostmatt's Avatar
    Jun 2014
    Hollidaysburg, PA
    174
    Once I tested TA, and it was 220, I said that was the last time. Ordered on that evening. It is well worth the money.
    ~Matt~ Radiant Metric 24'x52" 14k- built into a slope. CircuPool Si-30 SWCG. Jandy 200 SqFt cartridge filter. Pentair Optiflow 2-speed 1HP pump. Wanda the Whale. TF-100 Test Kit. Hard Plumbed.
    My Build w/ lots of pics
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    Magnetic stirrers all the way, baby!
    I have spent a substantial part of my professional life working in chemical laboratories. There's a reason we always use magnetic stir bars when doing titrations (actually, there are probably lots of reasons, now that I think about it), so it would never occur to me to do my own mixing. I'm only disappointed that the SpeedStir is run off a pair of AA batteries instead of plugging into my wall at 110V....or even better yet: plugging into my pool equipment service at 220V!! More power, baby!!!
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Use SpeedStir for TA and CH. The way to go for those 2 tests.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,011
    I voted no just because I dont have one.
    When I ordered my TF100, I was still new. I saw it on the tftestkit site, but passed with the consideration that it was just another pool gadget to suck more Federal Reserve notes from my already thread bare wallet.
    Now that Ive been around a while, I have changed my mind. My next reorder of regents will include this contraption.
    Divin Dave,
    Dec 2013
    East Texas
    86
    SpeedStir! I swirled manually for the first several months, but since I usually test at night I found that having the bright LED light really helped get accurate results (in the absence of sunlight). Plus it's faster and makes it look like I'm some kind of hyper-trained pool chemist.
    30X40' free-form gunite/plaster pool, 4-8' deep with flagstone beach entry, gunite "rock" retaining wall with multiple small waterfalls/planters, grotto/slide/waterfall combo, 18" raised spa with waterfall into pool
    Aug 2014
    Northern IL
    4,615
    Personally, vinyl pool with low CYA, low TA, stable pH. No need for me to spend the bucks right now allowing me to keep the cooler full of the good stuff!
    Jul 2012
    Central Texas
    436
    I haven't seen the need for it. A quick swirl of the tube and you're done. Also, if you know about where you're at, you can add drops to get close to that in larger increments, swirl to mix, add more drops in smaller increments, etc. there nothing wrong with speed stir but it isn't needed for accuracy.
    Central TX / 12K GAL / IG / SWG / DE filter / Pentair SVRS & 3 swim jet pumps / Spa bench and jets / Single body of water / No heater.
  20. Back To Top    #20
    mas985's Avatar
    Pleasanton, CA
    11,741
    I haven't seen the need for it either. For me, it is pretty easy to mix the reagents by hand.
    Mark
