Thread: Replacing pump motor question
    Jan 2011
    Richmond, Texas
    595
    Howdy quick question. I am replacing my motor for one of my pumps that went bad. In this schematic it shows item #6 gasket but when pulling apart my old pump it did not have a gasket. Should I purchase a gasket? Does it need it? http://www.poolplaza.com/pumps/stari...ro-parts-f.gif
    Here is my the page for my pump I am replacing.
    http://www.poolplaza.com/C-Max-E-Pro-Parts.html
    Approx 11K Gal. 10'X30' Semi free-form IG - 6 ' raised spa w/6 jets - 10' circle sun shelf with 1 bubbler - Waterfall - 3 / 1.5 HP pumps - Polaris 280 Cleaner - 3 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Valve Actuators - 5 Fiberstar Mini Laminars - 1 Fiberstars 2004 Illuminator - 2 Skimmers - 6 Returns - Caribbean Blue Pebble Tech - 600+ sq ft kool decK - Auto Fill - 2 Boston Acoustics VOYA RK5 Outdoor Rock Speakers - 2 TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers - Apple Airport Express - 1 Awesome View.
    twesterd's Avatar
    Aug 2014
    Pflugerville/Texas
    30
    Re: Replacing pump motor question
    That wet end looks the same as my Challenger. Part #6 is embedded within the housing and there are two versions of that part: (1) a round o-ring type seal, or (2) a round seal that has square edges. You need the right version. Your pump will definitely leak if its not there and it probably does need replacing. There is also a smaller seal that could be round or square depending on the version that should also be replaced (part #12). You should also replace the shaft seals (parts #4 & #7). They make "go-kits" or "tune-up" kits that have all the parts, but I discovered that they aren't reliable on putting the correct seals in the kit. Leslie's pool supply had all of those parts in stock for me, but its sometimes hit or miss on what's in stock.
    FYI: I just replaced my motor with a programmable EcoTech EZ 1.5HP VS motor for ~$350. It is MUCH quieter and significantly more energy efficient. I love it it ... if you haven't already bought the replacement motor it may be an option for you. It will mount perfectly on your wet end.
    In-Ground Gunite Pool: 10,000-13,000 Gal, Filter: DE Triton Purex FNS Plus 48
    Pump: A.O Smith 1.5 HP Motor attached to 2HP Self-priming pump, Pool Installed: 1994
    Test Kit: Leslie's Complete Pool Care DPD Test Kit and LaMotte ColorQ Pro 9 (love and use both)
    Cleaner: Polaris 360 Pressure Side
    Jan 2011
    Richmond, Texas
    595
    Thanks. This is my waterfall pump so I am not too worried about the energy efficiency but when my main pool pump goes I will look into a more efficient pump for sure.
