Thread: Wiring ground lighting to EasyTouch 8 Aux line
    Dec 2014
    Trophy Club/TX
    2
    I am trying to wire the low voltage wiring for ground lighting around my pool. I want to make sure that I have the wiring correct. Do I need to hook up one of the two wires to the Line 1 and the other to the Load 1? I am a bit confused because there is not a simlple +/- sign on the switch. Any help would be appreciated.
    Re: Wiring ground lighting to EasyTouch 8 Aux line
    On the EasyTouch relays, line connections are inputs, and load connections are outputs. Typically you would wire from the circuit breaker to the line terminal, then from the load terminal to the light or transformer.
