Thread: Rust stains on the bottom of pool
    Aug 2013
    dallas,tx
    79
    I noticed a few rust stains a few months back. I thought my husband sprayed some fertilizer pellets in the pool. The spots look about a 1/4 inch in diameter. Now I notice more closer to the main drain, and we have not spread any fertilizer. I have tried brushing, but this did not help. Any thoughts what this could be
    Test results today
    FC 3.4
    CC 0
    PH 7.8
    TA 70
    CH 270
    CYA 50
    Borates 50
    I have been using 10% bleach in case this has any impact
    2009 19k, IG, Quartzscape negative edge w/waterfall, 8' raised spa w/waterfall ,Pentair WF28 2hp, Jandy 1.5hp pump for water fall feature, Polaris 280 cleaner with booster pump,400,000 Jandy LXI heater, Jandy DE 60 filter.
    30,431
    Re: Rust stains on the bottom of pool
    Thanks for posting your test results.
    I think my first step would be to positively identify the stains as iron. Do you know to crush up vitamin C tabs, put them in a sock and then sink it down to be placed directly on the stain for five minutes or so. If the stain comes off or is very noticeably removed, it is an iron stain.
    Aug 2013
    dallas,tx
    79
    Thanks, I will try that.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    I put a bunch of Vitamin C in a knee-high stocking with some clean river rocks and tied a string to it, then tossed it in. It's easy to shove it around with the brush and fish it out later.
