Results 1 to 10 of 10
Thread: max e therm cycling
    Aug 2013
    cucamonga, calif
    4
    max e therm
    reyrey here, my max e therm is cycling once temp reaches 92 deg.it will sputter 1st then 1 minute goes by and burner goes off and comes back on.this will occur 2 more times until heater goes off and service light goes on. can some one help me sort through the possible part that has failed. my only guess is HLS. is this common with max e therm problem. thanks, rey
    ps0303's Avatar
    Jul 2011
    FL
    3,693
    Re: max e therm
    When it finally stops and the service heater light is lit, leave it turned on and remove the covers and then the dome top, flip it over and see if there is an LED lit other than the service one.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Aug 2013
    cucamonga, calif
    4
    Re: max e therm
    and if there is...what is being indicated. ty rey
    ps0303's Avatar
    Jul 2011
    FL
    3,693
    Re: max e therm
    Each LED has an abbreviation next to it to tell you what it relates to.
    Paul
    Aug 2013
    cucamonga, calif
    4
    Re: max e therm
    hello paul, my max e therm is cycling again however , this time it will heat to 104 deg. the intervals are 1 minute apart. I found a piece of filter grid stuck in the regulator and removed it but it still cycles. any thoughts? best regards rey
    Aug 2013
    cucamonga, calif
    4
    Question max e therm cycling
    Topics merged. Please keep everything relating to one question/project/issue together in one place. Thanks JasonLion
    hello TFP members, im having trouble with max e therm heater. it does heat to 104 but cycles most of the way. the intervals are 1 minute or so apart. I found the flow regulator with plastic stuck inside and removed it, however it still cycles. any ideas?
    ps0303's Avatar
    Jul 2011
    FL
    3,693
    Re: max e therm cycling
    If that's the case, you probably have a broken bypass then. System is them heating up and cooling off. Where you took out the regulator, up top of that inside is the bypass. Feels like a round disk. If you don't feel that, then that's your problem.
    Paul
    ps0303's Avatar
    Jul 2011
    FL
    3,693
    Re: max e therm
    See other post I replied to.
    Paul
    Central Florida
    84
    Here is my post with similar issue that ps0303 helped.
    http://www.troublefreepool.com/threa...996#post742996
    18k free form IG w/spa (4 jets), Paramount in floor cleaning system, Starite system 3 filter, Jandy 2hp ePump, Sta-Rite SR400LP Maxi-therm propane heater, Jandy aquapure/apurem 1400 SWCG, Jandy automation PS4 w/PDA, IntelliBrite 120v 5-G LED pool & spa lights, 2" piping and (3)4x12 (5)4x10 Fafco Sunsaver Solar Panels.
    I just experienced the same problem as the OP had. 4 year old heater cycling with the HLS led lit during the off cycle. Pulled the thermal regulator and found corroded and would not open when put in boiling water test. No one had the part locally, so ordered online, replaced and the heater is working perfectly!
    I am going to order a couple more as I believe my salt pool contributes to premature failure. I guess I should expect 3-4 years out of the regulator.
    A question to the experts then... Would it be a good idea to bypass my heater when I know I'm not going to be using the heater for a few weeks period of time? Could I prolong the life of all the parts coming into contact with the salt water by doing this? I'm only getting about 18 months life of the external safety pressure relief valve due to the corrosion.
    Thank you so much to the experts here for assisting me in solving my heater problem so quickly & efficiently. You guys ROCK !!!
    Brian
