Thread: Pool closed without shocking. Should I shock it now?
    May 2014
    North Atlanta
    5
    Pool was closed 3 weeks ago without being shocked first. Water lowered below skimmers, lines blown out and plugged, cover installed, ect. Water temp was in the low 50s and chlorine was 5ppm (CYA 60) when it was closed. Should I shock it now (with bleach) or would I be wasting time and money?
    Thanks for all your help!!
    24K In-ground plaster, Raised spa w/ spillway, AutoPilot Digital SWG, SC-48 cell, Jandy 1.5hp pump, Jandy CV460 cartridge filter, Polaris 280 w/ booster pump, Taylor K-2006 (didn't find you guys soon enough!)
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    Re: Pool closed without shocking. Should I shock it now?
    Don't worry. Open it before the water get's to 60 and you should be fine.
    Support the site
    30,431
    More importantly, you need to circulate water when you add virtually ANY chemistry so you don't want to elevate your chlorine without a way to circulate it. In short, don't do it.
