Thread: Magnum Force Wet end removal
    Dec 2014
    Corpus Christi, tx
    1
    I am trying to separate a motor from the pump housing to replace the motor. I can not get the a part. I have removed the coupler ring and there seem to be no screws holding them together.
    Any ideas?
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Magnum Force Wet end removal
    I am not sure what you have done so far but here is a drawing that might help.
    Remove ring 21 and the whole motor with impeller should slide out.
    You can then remove the screws that hold the motor to motor plate.
    Mark
    Citizen's Avatar
    Oct 2014
    Orlando, FL
    92
    Quote Originally Posted by SteveFreeman62 View Post
    Any ideas?
    Once you remove number 21, the locking ring, the motor and drive assembly should come out. Mind you it is probably a little stubborn because it has been installed for awhile. I would bleed the pressure in yours system to make it a little easier and then use a flathead screwdriver to pry it open. Don't go crazy with the screwdriver though, you may break the pump.
