Results 1 to 17 of 17
Thread: Need assistance replacing valve in tight spot
    Jul 2014
    Durham NC
    6
    My pump lost prime and went undetected long enough to cause damage from the heat. The outlet side has already been repaired. The pump itself is now working as expected, but the 3-way valve pre-pump is so distorted from the heat that it needs to be replaced along with the connection to the pump. The problem I am running into is that the plumbing is very tight. Here is a picture:
    Does anyone have any recommendations on how to replace the 3-way valve based on this tight area? Also, is there a fitting that can be used to attached to the pump that will allow it to be unscrewed if work is needed on the pump in the future?
    16K gunnite pool and spa with spillover. AquaLink RS system with PDA remote, 1.5 hp Pentair WhisperFlo (primary), 2.5hp Pentair WhisperFlo (spa), Pentair Clean & Clear 320 cartridge filter, Polaris Halcyon Booster pump, Jandy Laars II 400kbtu heater, Jandy AquaPure PLC1400 SWG
    38,394
    Re: Need assistance replacing valve in tight spot
    Welcome to TFP!!
    Looks like you are another victim of the builders thinking they are doing you a favor by having all fittings and no exposed pipe. I am not exactly sure what to suggest that will not require replacing lots of valves.
    I will say that you should add a union (like in the bottom right of your picture) between the valve and the pump and that will allow you to remove the pump.
    Surf Hawk's Avatar
    Sep 2013
    Santa Barbara, CA
    114
    Wow that looks tough. Are those Jandy valves? Some Jandy valves you can glue on the OD or the ID. If that valve circled is a Jandy, maybe you could cut through the grey connector part, and then use the OD of that to glue and adaptor on? Then move an elbow up to your new valve, and you'd have to put a new check valve in, unless there is exposed PVC behind the circled valve I don't see.
    22,000 gallon IG; plaster; 16x32 Rectangular, Depth 3.5-8Ft.
    Hayward Pro-Grid DE Filter - 48sqft w/ cellulose fiber & Hayward Energy Flo RS Pump - .75HP (1.85SF)
    Very old 312sqft solar system, TFT-100 Kit with Speedstir
    Jul 2014
    Durham NC
    6
    You are correct that those are Jandy valves. Unfortunately there isn't any exposed PVC behind the circled valve. I am intrigued by the idea of cutting of the valve (leaving the gray parts on both sides) and attempting to use a larger diameter valve (would need to reduce it prior to the pump then since that side cannot be reused).
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    I bought a 2" bit reamer and cut flush to the pvc side then reamed out the stub...worked great...you do have to use an electric drill...
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    Jul 2014
    Durham NC
    6
    Thank you for the advice boston62!!! Were you able to find a 2" reamer bit at Lowe/Home Depot or did you have to order it online from a specialty store?
    Jun 2013
    24
    Great advice Boston that's what I have done on jobs like this. Another option is to use 2.5 coupling with a 2.5 x 2 bushing into th pump. A tee and 90s and go over the top of the check valve and skimmer/md valves. This would require more plumbing but an option if Boston's advice does not work.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I always marvel at this when I see it, and it's on more set ups than not. I suppose they just imagine it will never have to be them repairing it.
    Which, is probaly the case the majority of the time. Sounds like you got some good suggestions to avoid cutting up the whole thing.
    Essential Links:
    If you cut the pipe flush with the three existing valves, you can use 2.5" fittings to make a new manifold. You could use a 2 x 2.5" or a 2.5 x 3" Jandy three way valve to go into the pump. If you use a 2 x 2.5" valve, you might need to move the pump over a bit, but that looks like it would be doable.
    Support the site
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Pasco 3244 2" ram bit I order it at Amazon.
    Autopilot SWG
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Quote Originally Posted by Brushpup View Post
    Or they just want to make it harder for the Pool owner to do the repair so they get the work?
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Jul 2014
    Durham NC
    6
    Thanks to all of the wonderful advice I received here I was able to get the valve replaced successfully. I ended up ordering a 2" reamer bit from Amazon. It is made by Reed and is part PPR200. I removed the fence so that I had more room for the job.
    Here is what it looked like with the 3-way valve removed:
    I was able to move the pump slightly and put a union in front of the pump. Here is what is looked like after the job:
    38,394
    Nice work. Only thing to note is that you did not use a schedule 40 90 fitting so it is not as strong. Hopefully will not be a problem on the suction side.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    I was looking at that too. The 90 on the left is a dwv 90 fitting so not pressure rated. I've read of people using them for many years without issue, so because it's a difficult replacement location, I would leave it as is, but keep and eye on it.
    Isolated Spa - 345 Gallons
    Jul 2014
    Durham NC
    6
    Will definitely keep an eye on the 90. I tried to save time by going to Ace Hardware to pickup the elbow rather than going to Lowes/Home Depot.
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    Quote Originally Posted by monroema View Post
    Nice job.
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    38,394
    Likely the ACE also had Schedule 40, they do by me. Likely it will be fine on the suction side, make note for next time
