Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: One question about Filter pressure gauge.
    Dec 2014
    Tampa, Florida USA
    31
    I installed a Hayward De6020 filter with 1hp pump. I'm only like 25ft away from the pool now compared to 70ft that i was before. My pool has 2 suction pipe 1 from the skimmer and i new one i made from the main drain everything with 2 inch pipe. then from pump to filter and from filter to 4 returns in the pool. I also connect my other 2 returns that were disconnected before. so i have a total of 6 returns. <---- i think this may be my problem but I'm just asking in case im wrong. The pressure gauge on my filter is showing 0-2 psi. but the returns in the pool have enough pressure. So I'm confused if this is normal. The original filter gauge broke so i bought a new one at pinch a penny and they gave me a oil pressure gauge. It looks like it has water inside. Please help and sorry for asking so many questions.
    Rectangular pool 32x18 with approximately 17k gallons w/ 1hp pump and Hayward DE 6020 Filter.
    38,546
    Re: One question about Filter pressure gauge.
    Can you be more specific about your pump and motor?
    With a large filter and 2 suction lines and now 6 returns with a smaller pump, you have a low head loss system so the pressure may be lower. Although 0-2psi seems a little too low to me. I only see that low if I am running the pump on low speed with a clean filter.
    If the flow of the returns is good, then there is not real issue. The glycerin gauges are better, but you may not get good accuracy if it is a 0-60psi gauge. Sounds like a 0-30psi like sold at tftestkit.net might help to get a better read.
    Dec 2014
    Tampa, Florida USA
    31
    This is my setup so far. About the pump i only know that is a 1hp and the suction is really good and there is no air bubble. I did notice tho that if i shut down 2 of my returns it will go up to 5psi
    30,432
    0-2 psi on a single speed pump doesn't sound right. What was the psi before your old gauge broke.
    Dec 2014
    Tampa, Florida USA
    31
    It was 10 psi but it only had 1 suction pipe and 1 return pipe. I added 1 more suction from the main and 2 more returns. so today i installed the new gauge and test my system and doesn't go above 2psi with all suctions and return on.
    Dec 2014
    Tampa, Florida USA
    31
    I explained wrong i meant before there were 4 returns connected to 1 - 2inch pipe. now i have 6 returns 4 that i had in 1 pipe and 2 extra in a new 2" pipe.
    30,432
    If the flow is adequate at the returns into the pool as you say, I would not worry about anything although I still think your psi gauge is wrong.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Adding an extra suction line should make it easier for the pump to get water to push and would allow more volume IF the single pipe was restricting supply. So adding an extra suction line would possibly allow the pump to push more water and that would raise pressure.
    Adding back in the two extra returns would make it easier for the pump to push water to the pool but you already had four returns so the extra two shouldn't be that big a difference. That and you said if you closed them you only went back up to 5psi when before you were usually around 10. I think you have an inaccurate gauge. I would highly recommend getting a new gauge and a quality one at that. The price savings aren't that much.
    If you get a glycerin filled gauge I do recommend making sure it's covered. My equipment is out in the open and after a few months I noticed my glycerin started to get a little dark. I cover it with a drink cup now.
    I went with the TFTestkits gauge after my cheap gauge made it a year and seized. http://tftestkits.net/Pressure-Gauge...Mount-p77.html
    Solar Blanket, Well Water, Borax Added. 76
    Dec 2014
    Tampa, Florida USA
    31
    guys the gauge they gave me on pinch a penny was 100psi will this maybe y problem?
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    That's just way too high to be very accurate. You need something more 0-30
    With a meter or gauge it's usually more accurate if the range you are reading is in the middle.
    Dec 2014
    Tampa, Florida USA
    31
    Ok I'm going to return this one and get a 30psi gauge i be back with results.
    38,546
    0-100 is just silly. Pool equipment is designed for 50psi, and the pumps can not even achieve that. I agree that a 0-30psi (that has 1/2 psi tick marks) is what most pools should be using.
    Dec 2014
    Tampa, Florida USA
    31
    This is the reading i get with this gauge on my new setup? You guys thing this may be the problem?
    38,546
    Get a gauge that is correct for this application. There are only 7 tick marks below the 10psi line ... so I think that might be 5psi. If that is right, then you would want to backwash at 6psi (a 20-25% rise) and differentiating this on that scale does not work ... assuming it is even accurate that low.
    Order one of these (click the gauge for a link):
    Dec 2014
    Tampa, Florida USA
    31
    can i use a regular 30psi gauge? like from auto part? or home depot. problem is i need one asap
    Sep 2013
    Dallas-Ft. Worth Metroplex, TX
    810
    I'm sure any local pool store will have one for you if you need it in a jiffy. Just might pay a bit more.
    14K Freeform Gunite w/60% Blue Quartz plaster, Quad DE filter, Intelliflo VS Pump + Booster for Cleaner, Aquacal Heat Pump
    30,432
    A local pool store is likely not to have a glycerin filled gauge but maybe a cheap, air-filled gauge.
    Not sure why you need it in a hurry but I would suggest getting a glycerin filled gauge with a 0-30 scale. (that's my link in jblizzle's post above)
    I obviously have some agenda, but, I promise, selling that gauge is not going to allow me to rub shoulders with Bill Gates but it will make you far happier to pay the extra money and get glycerin filled.......they're just better.
    It'll ship tomorrow if you order tomorrow and be to you by Monday/Tuesday.
    38,546
    I agree with Dave, there is not big urgency on this. Ordering a good one is likely the same cost as a junk one locally.
    Need any test kit refills while you are ordering to save on shipping cost?
    Dec 2014
    Tampa, Florida USA
    31
    one more question can air leak in the filter side cause this issue? It makes sounds like it has air inside but when i open the air valve and only water comes out.
  20. Back To Top    #20
    Dec 2014
    Tampa, Florida USA
    31
    How did i end up with DE on my pool if it is showing no sign of been sent throw the return lines? but i do see it on my pump when i start up the pump it turns white inside then clear and i do notice it on my main drain in pool too. help please.
