Thread: Trying to drain water from my pool but way too slow
    Question Trying to drain water from my pool but way too slow
    I have an IntelliFlo VS-3050 that's only about 2 years old. One of the issues I run into in the winter is being able to drain the pool quickly. Attached is a picture of the spigot I'm being told I should use. I'm simply firing up the pump with a hose connected to this spigot and running it to my drain pipe on the house. Even at full speed on this pump, water only trickles out of my 26K gallon pool that is over filled by the rain.
    Anyone know the best way to drain the water from this system quickly? Thanks for any help.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: Trying to drain water from my pool but way too slow
    Replace that spigot with a gate valve and a hose barb to connect a backwash hose. Or, if you have a multiport valve, set it to waste.
    38,283
    Or pick up a sump pump. Depending on how low you are trying to drain the pool, your pool pump could lose prime.
    Please add your location (City, State or City, Country) to your profile and pool details to your signature as described HERE as it will help us help you.
    30,419
    All the above ideas are better than this but I suspect what you are currently doing is allowing the water to return to the pool via the return lines except what little flows out that spigot.
    If you can throttle down your return lines the pump will likely produce a huge amount of flow out that spigot.
    If that doesn't work, I suspect your spigot is blocked.
    Awesome! Thanks everyone for the replies. I will give these suggestions a go to see what drains the quickest.
    Cheers!
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    You can throw a garden hose in it and siphon the water out for free. You can get thousands of gallons out in a day w/ a five-eights hose. You do have to be able to run the hose down a hill to a point lower than the pool, though.
    Good luck!
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
