Results 1 to 15 of 15
Thread: Mustard Algae keeps creeping back... even at 0 CC...
    Oct 2014
    Jacksonville, FL
    67
    Been doing TFP since October (only owned this house 8 mos)... anyway-- we SLAMd and SLAMd and got rid of our mustard algae, came back again, we SLAMd again... it's like after we SLAM it and pass the overnight test a month later it's back even tho we keep up our levels... what's the deal?
    For instance, last SLAM was Nov 1-4, then we let it drift back down to normal level... now, Dec 6 we suddenly saw a faint patch of yellow on the side of the pool-- it always starts on the same wall... UGH!
    ast time, I even had my husband swim around with a syringe of chlorine (from like a kids medicine syringe) and shoot it behind the light, into the drain on the bottom and around the laddar underwater! Is this happeneing becase our bottom drain is not in use? (So annoyed at how they plumbed this but the home inspector said it was allowed.)
    So, we will SLAM again, but why is this happening if we pass the overnight test, have a CC of 0 and make sure to keep eveyrhting else at rec levels? I mean, it's faint and it's just one wall, but I know it'll spread quick without SLAM.
    pH= 7.8 (this is always rising and having to add acid weekly)
    FC= 9
    CC= 0
    ALK= 75
    Calcium= 175
    CYA= 65
    THANK YOU!
    ________________________
    22,000 gallon pool---In ground--Oval--16x32---Vinyl liner -----Cartridge Pentair filter
    Pump= Century HSQ 165 (installed 2016) ---New liner in 2014 when we bought, orig. build date unknown
    Test kit Taylor K-2006---Manual vacuum---Bottom drain not in use, odd plumbing setup
    Re: Mustard Algae keeps creeping back... even at 0 CC...
    Have you read the article in Pool School on how to defeat mustard algae? You need to follow all of the steps or it will just come right back, as you have experienced.
    Also, CC has nothing to do with it. CC could well be zero the entire time, which doesn't really tell you anything.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Are you following the recommendation to pass all SLAM criteria and then raise the FC to mustard algae levels for a full 24 hours? Are you removing lights from niches, scrubbing out the niches during the SLAM and the MA FC raise? And removing ladders and scrubbing them with a dilute bleach solution?
    If it keeps coming back, there is some lurking somewhere even after you've SLAM'd. The overnight chlorine loss test (OCLT) has a high success rate of determining whether or not something is still growing in your pool and then you need to follow up with the MA FC level.
    Review this and see if you've been following it Mustard Algae
    Isolated Spa - 345 Gallons
    Jun 2014
    Oslo
    120
    It seems to me that you might have a circulation problem if the algae starts to grow in the same spot. If the deep end drain is not in circulation than you might have a temperature gradient from the surface to the depth. The cold water is heavier and will not mix with the water on the surface unless the return jets are pointing down. Measure the water temperature close to the surface and compare with the water temperature close the main drain when the pump is in use. If the water in the deeper part of the pool is not well mixed with the surface water, than it is not properly sanitized and the algae has a chance to grow. If you have a cover, use it. It helps by reducing the chlorine loses.
    South of France inground rectangular 17k pool - ruber membrane. Sliding dome, black thermal blanket covering 75% of the pool surface. Aqualux 3/4Hp pump, glass media sand filter, Zodillac robot, 110W UV-c lamp, Hayward brominator, Caliente 12kW heat pump.
    Oct 2014
    Jacksonville, FL
    67
    Yes-- followed the article and was guided through the process on here in Oct each day by some nice posters!
    Passed OCLT test many times after each SLAM.
    Not sure how to take lights off and ladder... how can I do that safely? Right now the water is way too cold to get in. When I made my husband go in Nov 1 he was shivering for an hour after, and now it's like 6 weeks later, so can't go in.
    Should I try to point my 3 return jets down?
    For now should I just SLAM and keep the level really high all winter or will it ruin my liner?
    I don't have a cover.
    Why do you think all is fine for a month and THEN it comes back? A month seems like a long time to have great reading and sparkling water before it comes back, doesnt it?
    This seems like a dumb question, but could it be coming in through the pine cones and needles falling in the tree daily?
    We REALLY followed all the directions of helpers on here and the articles-- we even made ourselves a waterproof manual from all the stuff on here and I take it out to the pool and refer to it each time I test, etc. Made a test sheet to keep track of what it all looks like over a month's time.
    THANKS!
    PS- Each SLAM we brush like crazy even if we dont see anything, 3x a day
    Sep 2013
    Dallas-Ft. Worth Metroplex, TX
    810
    Quote Originally Posted by ZESTR View Post
    Wow! It sounds like you really know what you're doing! Can you imagine having to rely on pool store advice for this!?
    Can you elaborate on the main drain thing? I imagine if the main drain is not usable, and there has been water sitting in those pipes for a long enough time, it could probably harbor some nasties, though I am no expert by any means on this stuff.
    Pointing a return jet down near the deep end should definitely help a lot with circulation. It can't hurt to try!
    Also, please don't torture your husband too much.
    14K Freeform Gunite w/60% Blue Quartz plaster, Quad DE filter, Intelliflo VS Pump + Booster for Cleaner, Aquacal Heat Pump
    Oct 2014
    Jacksonville, FL
    67
    Haha!
    Well, from what the home inspector told us, the main drain could work but by the pump it's capped off... so a plumber (?) would need to come re-plumb it and the inspector said the owner was just trying to save $$ so they did it this way. We are trying to save up so it can be functional again.
    This pool sat for FOUR years and was black when we first saw the house in March 2014--it had a big garbage bag looking tarp over it from the bank. In the process of buying, it was drained, re-lined, and new water filled. A company bought the house at auction and re-did it all, but obviously wanted to save $$. We bough it April 2014 and promptly went to Pinch a Penny (ugh)... 6 months later we were full TFPM but that was still 6 months of tablets to undo!
    Jun 2014
    Oslo
    120
    Stagnant water = trouble. Algae and bacteria will find refuge in those places where there is little water flow as the disinfection agents: chlorine or bromine will not be present in those places. The rest of the pool may be nice and clean, but pipes and other places without water flow will offer refuge for the nasties. Pointing some returns down might work, but I think is better to fix the main drain and have a proper water circulation. Best results are obtained if the flow is equally divided between skimmers and the main drain. Organic debris is using up the chlorine, so less is better. A cover will help to keep the water clean and debris free. Is the filter clean? If no, you know what to do.
    Sep 2013
    810
    That's pretty nice of them to have done all that for you before you bought the house. Reconnecting the main drain should be an inexpensive fix so I will second that recommendation.
    Oct 2014
    Jacksonville, FL
    67
    I know-- but inexpensive is all relative... I'll look into it, but we basically live paycheck to paycheck.
    Thanks!!!!
    Till then we'll... tread water?...lol--- and SLAM when needed.
    well-- no one would have bought the house like that-- it's why they bought it and flipped it at more than twice the price.
    Mar 2007
    San Rafael, CA USA
    12,082
    If you are unable to completely eradicate the yellow/mustard algae (and you might be in an area where it keeps getting re-introduced), then you have two options. You can maintain a higher FC/CYA ratio of roughly 15% to prevent it from growing, but being roughly double the amount of chlorine needed per day so more expensive, or you can use a supplementary product to prevent the algae from growing (a last resort solution).
    Some products that do well preventing green algae growth such as Polyquat 60 don't do well against yellow/mustard algae so generally aren't needed since chlorine alone will prevent green and black algae growth at reasonable FC/CYA levels (roughly 7.5% for non-SWG, 5% for SWG). While a sodium bromide algaecide product would work, it would also turn your pool into a bromine pool at least for a while until the bromine outgassed or got filtered out attached to organics. A phosphate remover would inhibit the growth of all algae types if phosphate levels are lowered to 100 ppb or below -- if you go that route, the economical product for this would be the Orenda PR10,000. Use of this product will temporarily cloud the pool until the precipitate of lanthanum phosphate and lanthanum carbonate gets filtered. If you decide to use a phosphate remover, get a phosphate test first, probably from a pool store since the Taylor K-1106 is not cheap.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    I don't know...I might resemble that remark )
    (My handle come from the foreclosure-black water-revival I staged three years ago
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Jun 2014
    Oslo
    120
    I would recommend sodium bromide only if the CYA level is high (~100 or more). Bromine is also less volatile and therefore more stable at higher temperatures, but this is not the case. If the main drain cannot be reconnected (for whatever reason) one should keep the level of the sanitizing agent higher and apply a daily dose of brushing. This will mix the water and prevent algae growth.
    30,432
    I would recommend sodium bromide only if the CYA level is high (~100 or more). A much less expensive and practical approach is to reduce your CYA level and keep your pool a chlorine pool..........not bromine.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,638
    I am guessing the main drain pipe is you main problem. That water is just sitting there and not telling what is growing in it.
    Behind your light might also be a problem but I am really leaning towards the main drain.
    Kim
