Page 1 of 3 123 LastLast
Results 1 to 20 of 42
Thread: Test Kit Arrived
    Jan 2013
    Friendswood, TX
    320
    Test Kit Arrived
    Received my TF-100 yesterday. Sure is a lot of bottles!!! Now I just need to learn how to use it.
    Started watching the YouTube videos.
    ~Paul
    19x40 IG including 10' BE, 18,000 gal, plaster, 48 SF DE, 1.5HP pump, AquaPure SWCG, Ozonejoe 30MR, Rockwaterfall, LED light, TF-100 Fill date 11/21/2014
    My ODK Build | My Pool Build | If You're From Texas Vote Here
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Test Kit Arrived
    Congrats on your kit! It's really the best overall kit around in terms of usefulness and value for a homeowner pool. I love the SpeedStir option as well.
    Check out the Extended Test Kit Directions if you want some more detail on the tests and ask questions if needed.
    Isolated Spa - 345 Gallons
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    Good to see you are taking control. You will be a Jr. Chemist in no time. It looks like a lot but it really is easy. Start keeping a log, soon you will start to see a trend and a feel for your pools personality. Over time you might not need to run every test every time. TA, CH, and CYA are the ones that don't change much. Good luck and ask questions. That's what TFP is here for. Everyone had to start somewhere.
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by jcowart View Post
    Keeping a log is a great idea. If you want to get your nerd on and use a great spreadsheet. JessieWV has put together a pretty good one here.
    Jan 2013
    Friendswood, TX
    320
    I was making a log, but stopped and downloaded the spreadsheet referenced above.
    I do have a SWCG, what should I set my salt ppm to be?
    ~Paul
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Whatever salt level is recommended by your particular SWG.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Congrat's on the kit. It really is easy once you run a couple of them. Ask questions if you need too. Salt is usually around 3500 PPM but look to see what you Mfr suggests to be sure.
    Welcome to the forum.
    Essential Links:
    Jul 2012
    Central Texas
    436
    PoolPal is a terrific app for keeping a log of everything and having it tell you what to do to get to your goals. The beauty of it is that it can be right there at the pool with you. Also very very easy o use it to see effects of different levels on the LSI and CSI indices (which not everyone needs or cares about).
    Central TX / 12K GAL / IG / SWG / DE filter / Pentair SVRS & 3 swim jet pumps / Spa bench and jets / Single body of water / No heater.
    Jun 2014
    Sanger, TX
    555
    Quote Originally Posted by JVTrain View Post
    I am a total spreadsheet geek - thanks for pointing this out, it is now downloaded - Karen
    New in 2017, will update
    Jan 2013
    Friendswood, TX
    320
    Just did a full set of tests. Here are the results.
    FC 2.5
    CC 0.5
    TC 3
    Br 4
    Ph 8.5
    TA 60
    CYA 50
    CH 500
    Acid demand 5 drops so I added1/2 gal of muradic acid.
    I have been chasing the ph since the pool was filled in November. We got about 2 inches of rain yesterday and it still tested above 8.2.
    How long should I wait after adding the acid till I test again?
    ~Paul
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Quote Originally Posted by Jabooh1 View Post
    FC 2.5
    CC 0.5
    TC 3
    Br 4
    Ph 8.5
    TA 60
    CYA 50
    CH 500
    With the pump on, half an hour should be plenty. You can ensure things are mixed well by brushing a little to set up cross currents.
    Jan 2013
    Friendswood, TX
    320
    Thanks!
    I'll go back out in a hour or so and retest. I brushed it after adding the acid.
    ~Paul
    30,432
    Br stands for bromine and you have none in your pool. That test is an OTO test for chlorine and is redundant when you do the far more accurate FAS/DPD Free Chlorine test (the one with the powder)
    Not sure how you tested 8.5 since the test only goes to 8.2. Nevertheless, you should not be "chasing" the pH but rather bringing it down by using PoolMath to calculate your dosage and muriatic to bring the pH down to around 7.5. Is that what you are doing?
    Jan 2013
    Friendswood, TX
    320
    Yes. I estimate it higher than 8.2. It is at least 8.2. By chasing I mean, chasing a proper ph value. I have added at least a gal of MA and have not seen a discernible drop in ph.
    ~Paul
    Smykowski's Avatar
    Sep 2011
    3,065
    Remember that the pH scale is logarithmic, not linear. The move from 8.5 to 8.2 will take a lot more acid than the move from 8.2 to 7.9
    I would use 8.2 as your start value, use 7.8 as your target, and add enough acid to achieve that move. Wait 30 min and retest. You may need to redo this several times - you know your pH is above 8.2, but it's impossible to know how high above.
    Jan 2013
    Friendswood, TX
    320
    Thanks for the explanation. I must not have caught that when I read pool school.
    Richard320's Avatar
    Jan 2010
    19,075
    Another possibility is that the acid you bought might not be full strength. If it says "low fuming" or "safer" or anything else, it's a good chance it's weaker than 31.45% and you need to select the proper strength to calculate the proper dosage. Also, your pool may or may not be the size you think it is. If it's bigger than you were told, you'll be underdosing all the time.
    Jan 2013
    Friendswood, TX
    320
    It is 31.45% MA. When I filled the pool I measured the flowrate of the hose into a 5 gal bucket so I should be close to the volume. It is possible to be off though. Tested it today. Seems much better.
    Cl 2.5
    ph 7.8 to 8 (I have hard time telling the difference)
    Acid demand was one drop to 7.2
    TA 40
    With the SWCG I need to TA to go up. Do I do TA adjustment first then counter the ph with MA or other way around?
    ~Paul
    Richard320's Avatar
    Jan 2010
    19,075
    Check out "Effects of Adding Chemicals" at the bottom of poolmath. You'll see that Baking Soda has very little effect on pH.
    Personally, I'd fix the pH first, since it has the most effect on scaling or etching, and then fine tune the rest.
  20. Back To Top    #20
    Jan 2013
    Friendswood, TX
    320
    Ok reread pool school and I think it might be starting to sink (haha) in. Just a lot of information.
    I need to keep doing MA treatments to lower the ph to 7.6. Then add baking soda to bring TA (because MA will lower it) to 60-80.
    One thing that the articles do is warn you of what can happen when chemicals are out of the suggested ranges. However it doesn't tell you how quickly problems can arise. If ph is high for a week or two or TA is low for a while, does that have great affects on the plaster?
    ~Paul
