Thread: new pool build in North Atlanta, pebble question
    Dec 2014
    Atlanta, GA
    1
    We are under construction on a shotcrete pool in North Atlanta. We are planning to have a pebble interior finish. It is starting to get cold earlier this year. Is there a minimum temperature acceptable to install the pebble interior? I've searched and searched all over and can't seem to find an answer. I am guessing that probably means there is not a problem with cold temps.
    Thanks!!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: new pool build in North Atlanta, pebble question
    Welcome to the forum! Sorry we haven't answered you yet on such an easy one. My apologies.
    It's generally accepted that it needs to be 40 F and up. Some opinions will vary a little.
    Essential Links:
    When are you planning on actually putting the pebble in? Soon or month or two down the road? We too are in north Atlanta and in middle of constriction but have at least a month to go before pebble put in.... Now another thing to stay on top of PB on.
    25k, IG, Marcite, StaRite 3/4hp motor/pump, Hayward S-240 sand filter, Hayward Vari-Flo 710x32 valve.
    Liquid Cl 10-12%, Muratic acid 31.45%, granulated stabilizer conditioner CYA 96%
