Thread: e90 error code on my intex purespa
    Dec 2014
    Chandler, AZ
    1
    Split by moderator. Please start a new thread for your own questions as you will likely get faster help that is specifically for you and avoid confusion in another member's thread. Thanks, jblizzle
    I am getting an e90 error code on my intex purespa any suggestions on how to fix it
    May 2015
    Mansfield la
    3
    Re: e90 error code on my intex purespa
    Same exact question no need to split where is the answer if any given.
    May 2015
    Mansfield la
    3
    Ok after research i guessed that there was a reset button on the impeller motor. I was wrong. While cleaning and dumping the spa i knocked the pump system over, this jar knocked the impeller out of its bearing gasket which prevented it from working. The motor is on the bottom of the system with easy access. 3 screws for the motor and guard and 5 to open the impeller chamber. The power connection is also an easy disconnect. It is working fine now. Try this fix first....
    Jul 2016
    Portola, CA
    1
    thank you so much for your post.We had also knocked the pump system over, so I recommend to anyone else owning this unit to dump the spa away from the pump unit. My husband followed your directions and now the heater is working fine with no E90 message! Yeah! also, he noticed the rubber gasket around the pump was loose, put it back on correctly, and the unit is now noise free for the first time since buying it. Thank you again!
    Sep 2017
    Punta Gorda Fl
    2
    Trying to fix my third motor by myself. e90 code, do you have any pictures of what you did to fix this problem. Just a 71-year-old lady trying to live within my means.
