Thread: adding calcium hardness increaser
    Apr 2014
    Bakersfield, California
    24
    Drained and refilled pool with 7 month old dark gray plaster (colorscapes).
    I have added liquid chlorine, CYA and MA. These are my test results:
    FC= 0.5
    PH= 7.6
    TA= 80
    CH= 100
    CYA= 20
    I am concerned as to how to add calcium hardness increaser without etching plaster finish.
    Can i dilute CH increaser in bucket of warm water before adding to pool? CH increaser instructions state just to broadcast in pool with pump running without premixing in bucket of water.
    Also should PH be a certain level before doing this?
    20K gal colorscapes dark gray plaster, no SWG, BBB method, variable speed hayward ecostar pump, pentair cartridge filter, hayward navigator cleaner.
    Re: adding calcium hardness increaser
    Broadcasting and brushing works OK as long as you brush quickly and thoroughly. If the calcium sits for too long, it can stick to the bottom. The colder the water, the faster the calcium can stick.
    Premixing in a bucket also works. I would recommend that you do not exceed 2.5 pounds of calcium chloride per gallon of water. Also, don't use warm water in the bucket; just use pool water. Brush after adding the calcium by dilution.
    Your pH is fine for adding the calcium.
    Support the site
    The issue with pre-mixing in a bucket is that it gets quite hot as it dissolves. If you are aware of that issue and use lots of water per pound of calcium it isn't a big deal, but if it catches you unaware you can burn yourself.
    Apr 2014
    24
    Thanks for the info. Also what is the minimum CH level should be? i would like to keep it on the lower end of allowable.
    Sep 2013
    Dallas-Ft. Worth Metroplex, TX
    810
    I would like to point out that FC should never be allowed to reach 0.5 even with no CYA. The minimum acceptable amount of chlorine is 2ppm with 20 CYA. If you let it fall below that you are asking for trouble.
    14K Freeform Gunite w/60% Blue Quartz plaster, Quad DE filter, Intelliflo VS Pump + Booster for Cleaner, Aquacal Heat Pump
    The lowest we recommend you allow CH to get with a plaster pool is 250.
