Thread: Considering having the walls shot with spray foam?
    Thinking of having a pool built and was considering having the walls shot with spray foam? Any thoughts or experiences with spay foam or insulating a steel walled pool?
    Thanks
    41x25x18 Humpback Haven
    Graduated from 16ft Intex
    Re: Considering having the walls shot with spray foam?
    Most people consider wall insulation a waste of time. It will help retain heat just a tiny bit, but isn't likely to be worth the cost.
    Mar 2011
    Scottsdale, AZ
    406
    Total waste of money, and if the compressive strength of the foam is less then what properly compacted soil is it could create issues.
    Check this out.
    http://www.engineeringtoolbox.com/he...nks-d_286.html
    Truly a piece of cellophane wrap over the top of the pool would do way more then any wall insulation. Not the product
