Results 1 to 8 of 8
Thread: Drained too much water? ~12 inches below the tile line
    Philadelphia Suburbs
    6
    After closing, I got a little aggressive a few weeks in draining the water below the tile line. I intended to maintain my goal of 2-3 inches below the tile line but wound up closer to 12 inches (I actually think the position of the hose to the pump acted as a siphon even after I thought the pump was off).
    Is that too far below the tile line? Am I risking anything by leaving it that low with a Noreaster headed my way this week and many nights of freezing temperatures (it has already been like this for ~3 weeks).
    Any advice is appreciated!
    18K IG Pool - refinished with Pebblesheen in 2012.
    Hayward heater, pump, mechanicals
    Aug 2007
    New Jersey
    14
    Re: Drained too much water? ~12 inches below the tile line
    I don't think that would be a problem. I didn't drain enough off last year, rain & snow filled it and I lost hundreds of tiles due to freezing.
    30,419
    I don't see any downside. A lot more folks don't drain enough.
    6
    Thanks - Last year I struggled to keep the water below the tile line all year with the snow and ice. I guess I won't have the problem this year.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I don't foresee any problems either. 😎
    Jeff
    May 2013
    Long Island NY
    419
    I don't see an problems either, I have already had to siphon some water out 2 times this yr because of rain. And I'm sure I will do it again after this storm. We are going to get 3 to 4 in of rain tues.
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    I also don't see a problem and with today's weather the water level will most likely rise a bunch
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Jul 2014
    Hope Mills, NC
    567
    If you have a cover on the pool, it could be an issue. The water supports the cover and if the water is low, the cover rubs on the coping rail. Kills em in one season.
    Not that I would know that!
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
