Thread: Stonescapes Puerto Rican blend?
    Dec 2014
    Gilbert
    1
    I originally picked the Tropics Blue Mini with abalone, but the sub came to clean pool and prep for final pre plaster... Showed him what I wanted... He said, that's the old stuff.. Showed me the Rican blend, with glass beads, said it will sparkle more... Looks great...
    Anyone have anything to say about that?
    Just wondering if it truly is the "new" stuff and will it shine more than abalone... Cost is the same for me.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Stonescapes Puerto Rican blend?
    Welcome!
    I would have to see a swatch of the two compared to give an opinion. Is the base the same color? Something to consider carefully if you've already chosen, because if it is, the water color will differ.
    Essential Links:
    Sep 2013
    Dallas-Ft. Worth Metroplex, TX
    810
    Welcome to TFP!
    If it were me I would stick with what I originally picked unless they could show me what it will look like with water in it. I don't like to be put on the spot like that and I imagine you aren't going to postpone plaster to start researching new finishes again.
    14K Freeform Gunite w/60% Blue Quartz plaster, Quad DE filter, Intelliflo VS Pump + Booster for Cleaner, Aquacal Heat Pump
