Results 1 to 9 of 9
Thread: Where Do I File A Complaint ?
    Apr 2013
    Sacramento, CA
    2,769
    So I have been using TFP and the BBB method for the past two years.
    This morning, after a major storm, heavy rain and leaves blown all over ( insert short word for very hot place ending in ll) I went out to survey my pool. In the overcast morning light I COULDN'T SEE THE WATER LEVEL ON MY TILES.
    Yep, with a pile of leaves in the deep end, scattered leaves through the pool, my water was so crystal clear I had to bend down to determine if my water had climbed above the top of the tile. My CC, even with a pile of leaves in the pool, was zero!
    Now this is a major problem -- My pool is so clear I can't see the water level!! Ok I wear bifocals and a hearing aids --- but crystal clear -- after a storm?
    I am a layed back guy--- I confess I an not a total true believer and check my water daily ---- heck -- I sometimes go a week allowing the Steiner pump to do its thing. And my pool is this crystal clear??? Maybe my wife has secretly hired a pool service?
    Maybe we need to require TFP dye in pools for old guys like me.
    Sep 2013
    Dallas-Ft. Worth Metroplex, TX
    810
    Re: Where Do I File A Complaint ?
    I already claimed poster child for tfp , sorry !!!
    If you look close enough you will see both of my main drains, perfectly clear from across the yard on a cloudy day!!!!!!
    14K Freeform Gunite w/60% Blue Quartz plaster, Quad DE filter, Intelliflo VS Pump + Booster for Cleaner, Aquacal Heat Pump
    Mar 2007
    San Rafael, CA USA
    12,082
    I ask you: Is there or is there not water in my 16'x32' pool with a 6' deep end?
    Jun 2013
    East TN
    309
    Kentucky Fried Chicken has a complaint box. Although your probably better off using it for toilet paper when you eat their bloomer pudding. LOL.
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Let this be a reminder for those who think rain destroys the pool.
    Good Job Mister!
    Essential Links:
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    chem geek.........
    We would expect no less from your pool!
    One way that I can tell that there is water in chem geek's pool is that the light is travelling at only 224,900,569 meters per second vs its full speed of 299,792,458 m/s.
    Also, as light travels through the water, some frequencies of light are absorbed. Therefore, applying absorption spectroscopy, we can deduce the presence of water by the characteristic banding patterns.
    In addition, the analysis also indicates that minerals such as calcium and sodium are present, which further supports the conclusion that there is water in the pool.
    Support the site
    30,432
    Sep 2013
    810
    The only way I was able to tell was the fact that the pool lights were on. Nobody in their right mind would dry run their pool lights.
