- Nov 26, 2013
- 168
Welcome to Austin. Water prices here go up rapidly the more you use. You'll want to limit how much water your pool uses, especially if you water a lawn. I would not use an auto-fill, because I want to capture the most rain possible. Also using trichlor (tablets) exclusively will eventually require a significant water change or your algae will get out of control. This website is an amazing resource of science based information. You can learn to test your pool and only add the chemicals it needs. No more shooting in the dark. No more trusting someone who profits from being wrong.
You paid for a very nice system and it looks nicely placed out. Sadly, I wouldn't run the UV at all. It's Texas, we get plenty of UV. You're just destroying chlorine. The infectious stuff you listed isn't going to be your problem. It's algae. Almost all the chlorine I add is to replace what is destroyed by sunlight. I don't need more UV.
Luckily for you. The water is cold and the days (sunlight) is short. You won't see algae for a while. You can learn what you need before summer and be ready for when it gets harder.
