Thread: Pentair Mobil touch two, not retrieving data?
    Dec 2014
    Goleta/CA
    1
    Hi, my brand new Mobil touch 2 won't retrieve data from my brand new intellitouch personality kit? I have power to antenna and RF light blinks when buttons are pressed on remote!
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Re: Pentair Mobil touch two, not retrieving data?
    Have you assigned the address? If you have done this, start looking for interference, however, if you were able to set an address, the unit should be talking.
    The following is from the owners manual pages 4-6.
    Setting up the MobileTouch Wireless Controller
    The following describes how to assign the MobileTouch wireless
    controller a communication address for the first time and to add a
    MobileTouch controller to a system with a controller already installed.
    After connecting the Transceiver cable to the IntelliTouch load center
    the system is ready to setup MobileTouch controller.
    To manually setup the MobileTouch controller:
    1. On the IntelliTouch Outdoor Control Panel, press the Reset
    button.
    2. First Time MobileTouch install: The three red System
    Control LEDs will be lit (solid). Wait a few seconds then
    press the “F” Filter button. For IntellliTouch model i10+3,
    press the “P” Pool Filter Pump button.
    Add a MobileTouch with existing MobileTouch installed:
    The three red System Control LEDs will be lit (solid). Wait
    a few seconds then press the “V” button or “1” button.
    3. The three red System Control LEDs and the auxiliary
    button LEDs will begin cycling. Wait until the LEDs stop
    cycling. The three System Control LEDs will start to blink
    on and off. The IntelliTouch system is ready to assign an
    address for the MobileTouch wireless controller.
    4. From the MobileTouch Advanced screen, press the lower
    buttons 2 and 4 at the same time. The Service Personnel
    screen is displayed.
    5. Press the button next to LOCK ON ADDRESS to access
    the next screen.
    6. Press the button next to LOCK ON ADDRESS to assign a
    unique frequency for the MobileTouch controller to avoid
    interference from other wireless devices within range of the
    MobileTouch transceiver.
    7. After selecting “Lock On Address” the MobileTouch
    controller is now ready to operate the IntelliTouch system.
    The “Service Personnel” screen will be displayed.
    8. Press Exit to return to the main screen or proceed with
    Step 9 if you are adding another MobileTouch controller
    while the IntelliTouch outdoor control panel LEDs are
    flashing.
    9. To add another MobileTouch controller at this time,
    repeat Steps 4 (page 5) through 8 for each controller, if not,
    continue with Step 10.
    10. Return to the Load Center or Power Center. The System
    Control LEDs will be flashing. Press the Reset button.
    When the “Auto” LED is illuminated the process is complete
    and the system is ready for operation.
    Factory Warranty Station for:
