Thread: Benifits of a side vs top piped Sand Filter
    Oct 2014
    Berwick/Maine
    9
    I'm replacing my worn out Hayward 3/4 HP pump and Side piped DE filter with a Hayward 1 HP pump and Pro Series sand filter. Are there any filtering advantages to a side piped sand filter (a little more expensive) over a top piped sand filter?
    https://www.hayward-pool.com/pdf/man...210S-S244S.pdf
    Advantages I acknowledge for the side piped Hayward S244S Pro Series Side-Mount 24-Inch Sand Filter is less external pipe, external pipe bends and presumably lower pump back pressure. Disadvantage is the Side-Mount cylinder has two holes (side and top) where the Hayward S244T Pro Series Top-Mount 24-Inch Sand Filter only has one at the top - more to go wrong or possibly leak if top or side seal goes bad. Does it make a difference in filtering, back-washing or something I did not consider?
    18x36 In-ground vinyl pool
    Re: Benifits of a side vs top piped Sand Filter
    It is mostly a size/cost/convenience issue. Side pipes are a bit more expensive, but noticeably more convenient. It is fairly common to see top pipes on smaller less expensive filters, fairly unusual to see top piping on larger filters. I don't like top pipes because it makes it much more difficult to open up the filter and clean it out or service it.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by JasonLion View Post
    This is the major difference. Cleaning the sand in a top valve filter is more difficult. If you do get a top mount, make sure you have unions installed fairly close to the valve on both the inlet and outlet lines. Then when you do need to service the filter, you can easily disconnect the valve from the filter body. Without unions, you'll have to cut lines in order to remove the multi-port valve. Might as well install unions right away.
    Some brands of top mount filters are prone to developing very slow leaks around the rubber o-ring that seals the top valve to the filter body. O-rings are cheap, but this is another reason to be prepared with union installation on the valve lines.
    Isolated Spa - 345 Gallons
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Go bigger than you need, and side pipes. You'll never regret it.
    Essential Links:
    Oct 2014
    Berwick/Maine
    9
    Thank you for the feedback, sounds like side piped filter is the way to go.
