Thread: Non Chlorine Shock Treatments
    Dec 2014
    Burnaby Canada
    1
    Hello,
    I have an indoor endless pool (about 5ft by 15 ft by 8 ft) and I am using a non chlorine shocking treatment but my CC is always high after using the shock... both Free Chlorine and Total Chlorine increase after using the product as well.... which makes no sense to me... I use a taylor test kit... as well my cyanic acid levels are 50ppm even though I don't use stabilized chlorine there is no mention about stabilizing agents in the shock agent but could it be from there?...
    Thanks
    Mike
    Sep 2013
    Dallas-Ft. Worth Metroplex, TX
    810
    Re: Non Chlorine Shock Treatments
    Welcome to TFP Mike! The only reason you would need to shock is if you aren't maintaining the proper level of chlorine in your pool.
    14K Freeform Gunite w/60% Blue Quartz plaster, Quad DE filter, Intelliflo VS Pump + Booster for Cleaner, Aquacal Heat Pump
    Welcome to TFP!
    Non-chlorine shock will often show up as CC until it is used up or dissipates, depending on which test kit you are using.
    What are you using for regular chlorine? Have you ever used bromine tabs?
    Support the site
    Mar 2007
    San Rafael, CA USA
    12,082
    The Cyanuric Acid (CYA) is likely coming from the source of chlorine you are using -- either Trichlor tabs or Dichlor chlorinating granules. As for the non-chlorine shock (potassium monopersulfate), you can get the Taylor K-2042 to remove interference from the non-chlorine shock. If you are properly dosing with chlorine and don't let the CYA get too high, then you may not need to use any non-chlorine shock.
