Results 1 to 7 of 7
Thread: Heater suggestions please
    Hi, we live in NH and have an 18,000 AG pool. We have used solar panels for the past few years, but they are just not getting enough sun. So I have finally convinced my hubby to purchase a heater. I am thinking something with a quick heat up for the weekends, but using the solar and cover to maintain the heat during the week. From what I remember reading a heat pump is slow and wouldn't work well with the colder Nh temps. So I need a gas or electric heater? Any brand or model suggestions? How many BTU's? Anything else I need to consider?
    18x33 above ground pool, vinyl liner, starbright DE filter, 1.5 HP Dynamo pump
    38,262
    Re: Heater suggestions please
    Raypak consistently seems to get the most recommendations on the forum, both from users and service people (since they are simpler designs and have fewer problems).
    Gas is usually cheaper to run than electric. Buy the largest you can afford and your gas pipe can supply. It will use the same amount of gas to heat the pool, just do it faster.
    ps0303's Avatar
    Jul 2011
    FL
    3,689
    Raypak 400K BTU gas heater would be what you are looking for. Hopefully you have natural gas where you are at as propane can be expensive.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    No gas line at the moment, debating the costs. Thanks for the suggestions. I'll check into the raypak models. Do you have any idea how much propane it would use?
    Citizen's Avatar
    Oct 2014
    Orlando, FL
    92
    Quote Originally Posted by ps0303 View Post
    I second this. Especially with you being in NH you will need the extra BTU. I was in Maine in July this year and I was freezing my butt off at night, so I imagine your need for heat will be high.
    I would go with Raypak because they know their product so well and they are very knowledgeable when I have reached out to them for help.
    ps0303's Avatar
    Jul 2011
    FL
    3,689
    A 400K BTU unit will use about 4gals of gas an hour.
    Paul
    I have had a Pentair MasterTemp 400HD for the past three seasons for my 19,000 gallon vinyl in-ground pool. I get about a 2F temp increase per hour in Central PA. I keep solar cover on to minimize heat lose. Burning natural gas is very convenient and less expensive than propane, but i think you can start with propane orifice and change out later for natural gas. As stated, use a licensed contractor for all that technical stuff when dealing with gasses.
    Good luck!
