Thread: Comparing LED light irons
    Jul 2014
    Orlando, FL
    12
    I have a small, 10K, inground pool. It's kidney shaped with the light fixture at the middle, i.e. pointing to the narrow side with the largest parts of the "kidney" to the left and right (I say ask this to explain that I need a light with a broad, not narrow, cast). I definitely want to change out the incandescent bulb with an LED. Different color programs weighs be a plus, but not mandatory. I'm comparing the following products, but writes appreciate any commentary on these or others:
    http://www.amazon.com/Swimming-Light...67CP8F0CC7EPSX
    $200, 500W equivalent (50W actual), white-only
    20 high power LEDs, No lumen rating given
    Vendor responses don't indicate much knowledge or helpfulness
    http://www.amazon.com/Swimming-BRIGH...7617571&sr=1-2
    $210, Replaces 500W or less (35W actual)
    Colors with programs
    545 LEDs, no lumen rating given
    http://www.amazon.com/Swimming-Light...YRM0XK0H28889Y
    $138, 250 LEDs, Replaces 300W or less (20W actual)
    http://www.amazon.com/Bulbwizards-Po...sin=B00C0FGKKW
    $164, 202 LEDs, 30W actual
    Claimed to be 500W equivalent but commenters say 2-300W
    Detailed lumen ratings given by color (white=11850, avg=600)
    Great vendor response to questions, good web page
    10,000 gal in-ground; 1hp single speed pump; Puck chlorination; Pebbletek; Hayward C1200 filter. Coming: solar, Intermatic PE953RC and Z-wave.
    Apr 2013
    Sacramento, CA
    2,769
    Re: Comparing LED light irons
    Most pool owners find LEDs are not as bright as incandescents.
    Citizen's Avatar
    Oct 2014
    Orlando, FL
    92
    Quote Originally Posted by gwegan View Post
    Also they find that the light have a different hue than the old incandescent lights.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    I've only seen a few folks on TFP review or talk about the Pentair Intellibrite niches and those comments have been positive. They are very expensive though. For the most part, the cost of LED bulbs will provide the wow factor of color changing but will not pay for themselves in electricity savings over the life of the bulb. If all you want is a white light, it's cheaper to just use old school incandescent... as long as they're available.
    Isolated Spa - 345 Gallons
