Results 1 to 14 of 14
Thread: Heater advice??
    May 2014
    Westport, MA
    28
    Heater advice??
    I am considering putting a heater on my pool to extend the season.
    Any advice is welcome..... I do not have access to natural gas, so it would have to be propane, or a heat pump.
    THanks
    18X36 inground with vinyl liner.. Hayward DE .... Upgraded to Hayward Ecostar
    26,700 gallons....
    ps0303's Avatar
    Jul 2011
    FL
    3,689
    Re: Heater advice??
    Propane is probably expensive but really nice as it would heat up faster when you wanted it. I see you only have a pool so probably a heat pump is the way for you to go. You will find some goo info on this board for either type you decide to go with. Costs for the units, gas or electric are pretty close. Just keep in mind that on a heat pump, when your outside dips below 60 the unit is not as good at producing heat. You will probably be able to extend your season by a month or so in fall and then open earlier in the spring.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Sep 2013
    Dallas-Ft. Worth Metroplex, TX
    810
    Re: Heater advice??
    Aquacal has a heat pump operating cost estimator that might be useful for you in determining if it would be worth it to own one in MA. I am thinking it's probably not, as Paul indicated they are very inefficient at temps below 60. Do you know what you are paying per kWh?
    14K Freeform Gunite w/60% Blue Quartz plaster, Quad DE filter, Intelliflo VS Pump + Booster for Cleaner, Aquacal Heat Pump
    Dec 2009
    Central Massachusetts
    2,690
    Re: Heater advice??
    I live in worcester county, gt, and I can tell you it wont extend the season much. Those nasty 45-53 degree days with an east wind we get in early and mid May, that heat pump might was well be at the bottom of the pool. I have a heat pump, but I put a 400k BTU propane heater on 2 years ago. I havent run the heat pump since.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Citizen's Avatar
    Oct 2014
    Orlando, FL
    92
    Re: Heater advice??
    Quote Originally Posted by zethacat View Post
    I thought Aquacal's calculator was a little difficult to use so I normally go with Raypak's. Maybe I am just simple lol but Raypak's calculator is a bit more straight forward for me.
    Raypak Sizing Calculator: http://roxwebdev01.pixelgate.net/gas...ak.php?appid=1
    ps0303's Avatar
    Jul 2011
    FL
    3,689
    Re: Heater advice??
    Quote Originally Posted by bk406 View Post
    This sounds like a real life scenario to me. Gas is the better way to go but if you only have propane as an option, it can get expensive.
    Paul
    Dec 2009
    2,690
    Re: Heater advice??
    Solar cover is a must. Hard to tell how much it cost me for the pool. I use the propane for a fireplace insert in the winter too, as well as cook with it. My best guess is I spend around $800a year on the pool heat. But i only heat it up when i want to use it. But the solar cover, i cant emphasize enough, is a must have.
    Oct 2007
    Parkland, FL
    752
    Re: Heater advice??
    Heat pump cost estimators are a bit misleading. You have to account not only for the electric for the heatpump but also for the electric the pool pump is using when you are running it 24 hours a day to heat your pool with the slow heat pump. Also the warmer the air is by the heat pump, the more efficient it is so if your heat pump is on the south facing side, it will work better. My old heatpump had to go on the north facing side of the house and was less efficient than my new one on the south facing side. I had propane at my old house before I swapped for heatpump, I just couldn't deal with 600 plus bills every time I needed to fill the propane tank. A solar cover would be an absolute must in Mass, one of the reasons I moved out of there and down to Florida. Also for a 26000 gallon pool, you would likely need 2 heatpumps as one big heatpump will barely handle the pools down here and most of them are 12000 gallons.
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    Sep 2013
    810
    Re: Heater advice??
    Quote Originally Posted by robl45 View Post
    This is true, but you should not need to run your heat pump 24 hours a day. If you are just using it to extend swimming season, and not for spot heating in the dead of winter, it should only need to run for a few hours per day at most to maintain the desired temp.
    Oct 2007
    Parkland, FL
    752
    Re: Heater advice??
    I guess it depends on where you are. I had to run it 24 hours a day in winter and still it didn't keep up. And winter in South Florida has a better temperature range than most places that are trying to extend a month before or after. I didn't have a cover though. Still my electric bill was over 400 dollars higher than normal.
    Nov 2011
    Moberly,MO
    1,010
    Re: Heater advice??
    With a heat pump it is recommended to run pump continously so the heat pump can maintain temps rather than try to jump temps. That being said I would choose a gas heater in MA over a heat pump. Here in Missouri about the earliest we can gain anything consistently is from mid April maybe to mid October. A cover is a must with a heat pump whether it be a solar blanket or a auto cover.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Dec 2009
    2,690
    Re: Heater advice??
    Probably true in Dallas, but in Massachusetts in the first half of May, you can get days that are 53 degrees with an east wind. Down right brutal.
    Sep 2013
    810
    Re: Heater advice??
    53 and windy isn't too bad. A heat pump will still work. As long as the average daily temp is 60, it's worth it to run the heat pump. After that, it becomes more of a drain on your wallet. But as I had stated in my original reply, I don't think MA is a good location for a heat pump. Also depends largely on the size of your pool. My 14000 gal pool doesn't require much to heat it up.
    Oct 2007
    Parkland, FL
    752
    Re: Heater advice??
    I don't know about you, but when its low 60's, my spa would take an hour to heat up, takes 15 minutes when its 80 plus degrees, a heat pump at 53 will barely do anything. In mass with a large pool, gas is the way to go, but its expensive. My friend had a decent size pool with a gas heater in mass, and they were quite wealthy and still his dad didn't want to turn the heater on because it cost so much.
