Results 1 to 8 of 8
Thread: AquaRite Cell or PCB problem?
    Well, the summer was going perfectly for my pool, thanks to this forum. Unfortunately, I've been stricken down by the green devil. My SWG has fallen again in its battle against algae.
    I have a Naturesoft/Goldline AquaRite SWG, almost 5 years old, on its second cell which is about a year old. First, the flow switch died (AGAIN) while I was on vacation for two weeks. Yay, fun. I fixed that, only to find the thing just doesn't like life anymore...
    When initially powered up, the green power LED comes on, and the LCD screen displays "Err" for about 2-3 seconds, then it disappears. I can't say I ever noticed this before. Is that normal?
    Next, normal start up appears to occur, with the flow light flashing for a minute or two. It eventually decides there is flow, and the green generating light kicks on. A bit after that, I hear a click, as generation actually begins, and the voltage and amps readings fluctuate as things stabilize. I'm reading around 25.1 volts, and 4.1 amps at this point.
    After 2-3 minutes, the generating light shuts off, and the "Test Salt Level" and "Inspect Cell" lights go on at the same time. Sometimes they flash. Sometimes they don't. Either way, I'm no longer generating chlorine. The system indicates the salt level is 2200 in the short period it is generating.
    I inspected, cleaned the cell, which is only about a year old. It looks pristine inside.
    Does anyone have any clue as to where my problem lies - cell or PCB? I'm out of warranty at this point (I think, system is nearly 5 years old). I don't want to pay a kingly sum to someone to come out and tell me how much more I have to pay.
    Thanks in advance!
    FC 0
    CC 0
    CYA 60
    PH 7.6
    TA 160
    Salt 3200 measured
    Pool a pleasant, green tea shade.
    22,500 gal Pebbletec pool
    8 Cartridge Hayward filter (!) w/2HP Pump
    AquaRite SWG - R.I.P. and good riddance!
    Automatic Liquid Chlorine Injection System - home crafted
    Jul 2008
    Pittsburgh, PA
    118
    Re: AquaRite Cell or PCB problem?
    have you tried acid washing your cell? That is the most common problem. I find it strange you have had 2 bad flow switches, I have never had one go bad on me.
    Matthew
    Involved in the pool and spa industry
    Pittsburgh, PA
    Guest
    Quote Originally Posted by schwim
    FC 0
    CC 0
    CYA 60
    PH 7.6
    TA 160
    Salt 3200 measured
    Your TA is very high which, I suspect, makes it difficult to maintain proper pH. Also, you did not post your calcium hardness, which is an important parameter for a SWG,o matter the pool surface.
    You could have a control board problem but I suspect that it might also be a water balance issue. How are you testing your water BTW?
    You might want to read these posts on water balance for SWGs
    category/pool-school/water_balance_saltwater_generator
    viewtopic.php?f=21&t=3663
    30,400
    Until you solve your SWG problems, I would suggest you shock and quickly start manually chlorinating your pool with bleach. The algae bloom is well underway and will get much worse if you don't get chlorine in your pool.
    Unfortunately, that is a way of life here in Arizona. Our water is very hard. Even replacing the water does not help... I've been maintaining the TA level between 140 and 160 for several years by adding acid and aerating. Other pools I've had suffered the same, as do friends of mine. Its a fact of life.
    CH is also way up there, above 600 I believe. I stopped measuring it since there is nothing I can do about it.
    Either way, the SWG has worked perfectly under these conditions until these last few weeks.
    Yep, I'm already on that. I added lots of bleach last night, heading to target on my way home to stock up on more. The only reason I didn't do this earlier is it is difficult to see the quality of the water in my pool without walking out to it. The pool is actually about 60 feet out from my back patio.
    Guest
    It IS possible to get your TA lower. With the high CH it is almost imperative to do so.
    Perhaps this thread will help you:
    viewtopic.php?f=8&t=5341
    Quote Originally Posted by waterbear
    Yes, that is exactly what I have done/still do. The lowest I've been able to get it is about 140. It doesn't seem to stay there though.
