Thread: Keeping above ground open all winter
    May 2014
    Virginia Beach, VA
    56
    Do I need to continue to test and maintain FC levels all winter...once the water maintains a temp below 60 that is??
    Right now I'm prob averaging adding around 8-10oz of bleach per day with water temps bouncing between 55-62 degrees.
    I'm not covering and will keep my pump running on low 24/7 during the time when the outside temps are in the 30's. (which its not yet)
    24' Round Above Ground - 13,500 gal, Cartridge Filter, Installed on 5-7-14, First Time Pool Owner! TFP True Believer!
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Since your not going to totally close it, maintain your water chemistry just as normal. You'll lose less FC per day with the water temp being colder and the sun angle being lower. You'll still lose FC though. Algae will have a harder time starting with colder water temps, but since you plan on keeping it open maintain your FC range for your CYA level.
    Jeff
    Jul 2012
    Central Texas
    436
    Re: Keeping above ground open all winter
    Similar discussions in another thread and it was also recommended to continue testing pH and TA as well although those parameters may need to rise a bit t compensate for the lower temps.
    Central TX / 12K GAL / IG / SWG / DE filter / Pentair SVRS & 3 swim jet pumps / Spa bench and jets / Single body of water / No heater.
    May 2014
    Virginia Beach, VA
    56
    Roger that. Thanks for confirming it for me. I appreciate all the support on this site!!
    Its been a great first pool year, can't wait for another trouble free summer!
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Stay with the guidelines here and every year will be great. 😎
    Jeff
    Sep 2013
    Dallas-Ft. Worth Metroplex, TX
    810
    And now you have the added benefit of not having to re-open it!
    14K Freeform Gunite w/60% Blue Quartz plaster, Quad DE filter, Intelliflo VS Pump + Booster for Cleaner, Aquacal Heat Pump
