Thread: KreepyKrauly spends most of its time in the deep end
    I have a Pentair KreepyKrauly Platinum cleaner. It spends most of its time in the deep end. Is there an adjustment I can make so it covers the floor uniformly?
    Pete
    15,000 gallons IG pebble, Sundek plus Luederstone, Pentair FNS Plus 60 DE filter with SM-20-2 valve, Pentair Intelliflow VS pump, Pentair EasyTouch 4 panel, Pentair KreepyKrauly Platinum cleaner, Stenner 45M fixed 10 GPD pump with 15 gallon tank, new pool startup 10/2012
    Sep 2013
    Dallas-Ft. Worth Metroplex, TX
    810
    Re: KreepyKrauly spends most of its time in the deep end
    Have you tried adjusting the jets?
    14K Freeform Gunite w/60% Blue Quartz plaster, Quad DE filter, Intelliflo VS Pump + Booster for Cleaner, Aquacal Heat Pump
    Do you mean the returns? After you responded I did some googling and adjusting the returns so the hose doesn't get pushed to one side is the primary suggestion for adjustment. I'll have to watch the operation closer but I don't think that's it. I have five returns and they are set to move the water counter clockwise around the pool. This is fairly effective in getting leaves moved to the two skimmers and one PoolSkim and there is no current such that the hose would stay in the deep end. My first guesses would be there might be something that causes the tractors to keep bearing slightly to the right or there is something about moving upward from the deep end to the shallow end that provides a lesser resistance to going downhill instead of uphill. If it matters, I run the Kreepy for 1 hour for bottom cleaning and the pump on high speed for one hour for skimming.
    Pete
    Sep 2013
    810
    I'm talking about the jets on the cleaner itself. Did you RTFM?
    Thanks. RTFM is always a good idea I found the info and will play with that.
    Pete
