Thread: Yellow stains in pool?
    Mar 2008
    Florida
    81
    Ok, now this is bizarre:
    Chlorine 3.0+
    pH 7.6-8.0 (fluctuates upto 8.0 every 3-4 days - usually about 1-2 cups acid brings it back down to 7.4-7.6)
    TA 70
    CYA 30-40
    CH 350
    I have had some minor staining issues since the pool was built in late june. The PB came and took care of them in early july. I saw some more in early july and he also took care of those. He told me that what they do is use a pvc pipe and pour muriatic acid over the spot using the pipe to guide the acid to the bottom of the pool. The last few stains I had seen where about two weeks ago and i was able to use the same method with no problems. Today I noticed several spots where there have never been problems before! Even some yellowing on the walls! Is this from the acid? Whenever I do add acid i first dilute it in a bucket and then poor it around the perimeter of the pool. That is the only thing i could think of that could possibly have gotten to all of the spots where there are stains. The other thing is that it has been raining here alot over the last few months. I have used a stain sequestrant twice - first at start up and again in july. I havent this month yet as i figured that the pool was balanced and cured. Should i continue? Anyone know what the source of the yellow stains are? I have stopped using the trichlor pucks about a month ago, just BBB at this point.
    frustrated with pee stains in pool!
    12-15k gallons capacity, 18'x34'
    2 main drains 4 returns 1 vacuum line
    pentair intelliflo 4x160 pump 200 sq ft media filter full width (~7' wide) swimout at deep end
    pebble sheen white diamonds
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Yellow stains in pool?
    The sequesterant is not a cure, or a one time deal. Usually if you have metals in your water, maintenance doses are required to prevent stains from returning. Also, keeping your PH at 7.2-7.4 may help prevent the stains from returning. So search on here for the recommended metal sequesterants and use it for maintenance purposes, like monthly or so? Good luck!
    Mar 2008
    Florida
    81
    Cool, thanks mom. I will check it out, just wanted to be sure I was at least walking down the right path
