There was one there, but someone had removed the flapper in it, it was just before the chlorinator which i removed and installed swg, i better put one back in. Thanks for the help.
Yup. Trichlor feeders make acid water, even when pump is off, which can apparently backfeed into the heater. The SWG does not make acid water and it does not generate when the pump is off.
