Results 1 to 20 of 20
Thread: Checking reasonableness for winter care?
    Jul 2012
    Central Texas
    436
    So during the summer, when my salt cell was at 60% and a 12 hour run time, I was adding ~4ppm per day. Chlorine stayed pretty consistent, so drop was about 4ppm per day.
    In this season, with reduced sunlight, I'm seeing about 1.5 to 2 ppm loss per day. CYA is at 70.
    So that equates to approx. 50 ounces of bleach per day?
    Is that a reasonable number / expectation?
    Just asking because this is the first winter I'm caring for the pool myself, rather than outsourcing it.
    Have adjusted to keep pH at 7.8, TA at 70, CH at 310, CYA at 70.
    CC gets to be 0.5 when significant wind or rain comes in during the day/night and then goes back to 0 the next day.
    Using generous rounding, 50 ounces equates to 3 gallons of bleach per week, so approx. $9.
    So assuming 27 weeks between now and being able to kick the salt cell back in, that's approx. 81 gallons of bleach and $243.
    Does this all sound reasonable, for those that have been doing the winter care routine for a while?
    Will have to check Sam's club and see if Clorox is cheaper there in a larger case than it is at HEB.
    Should I be adding this on a daily basis? Or can I add double the amount, say every 2 days, and let it come back down over a longer timeframe?
    Central TX / 12K GAL / IG / SWG / DE filter / Pentair SVRS & 3 swim jet pumps / Spa bench and jets / Single body of water / No heater.
    Sep 2013
    Dallas-Ft. Worth Metroplex, TX
    810
    Re: Checking reasonableness for winter care?
    Every pool is different. Does your pool see a lot of debris on a daily basis? What is your water temp? Make sure you are checking the manufacture date on those bleach bottles. I usually look for bleach that has been manufactured within the last 30-60 days. Don't buy any bleach that you suspect is being stored outdoors since storing it in the sun can cause it to depreciate faster. It doesn't matter what brand bleach you buy; bleach is bleach. 50 Oz of 8.25% should raise your FC by 2.8. If you're not getting a 2.8 ppm increase after adding 50 Oz, you're using depreciated bleach. It is perfectly fine to over-chlorinate but I think you will spend more money in the long run if you do it that way.
    14K Freeform Gunite w/60% Blue Quartz plaster, Quad DE filter, Intelliflo VS Pump + Booster for Cleaner, Aquacal Heat Pump
    Jul 2012
    Central Texas
    436
    Hmmm....You're right on the 2.8. Was thinking it was 2. Have been using PoolPal since it's on my phone which can be beside me while testing. The bleach percentage in the app was set to 6, not 8.25. Ooops. As to depreciation, I haven't seen a Born On Date on a bleach bottle....at least not on the Clorox ones I've been buying.
    Regardless, I don't think it is, since this morning it was 7 and I added in 50oz and it now reads 9.5. (CC was 0)
    Have been trying to keep it on the higher side due to being a little paranoid about something getting in there when the salt cell isn't contributing to anything. Maybe too paranoid. Also, TFP for non-salt says 5-8 and since I'm effectively not using the salt cell, I've been keeping it around 7.
    Water temp ranging between 53-61 depending on the sunlight we're getting.
    There's always something in the pool...landscaped around 85% of the perimeter and about 40% of that is with roses, so lots of petal loss in wind, etc. The mouse does a good job during its daily cycle and cleans it up.
    Sep 2013
    810
    Sounds normal to me.
    Most brands of bleach, if not all, have a manufacture date on the bottle. Clorox definitely has one. Take a look at this thread:
    http://www.troublefreepool.com/threa...asure-Strength
    Also, about bleach depreciation here:
    http://www.troublefreepool.com/threa...life-of-bleach
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Plus it would be cheaper to go with Walmart's great value brand. It's cheaper than Clorox and no difference. Just make sure it's regular household bleach. Don't get the easy pour jug ! It's not regular house hold bleach. 😎
    Jeff
    Jul 2012
    Central Texas
    436
    Ah...ok. The magic decoder ring helped, thanks! Saw that stamp, but didn't know what it was. My current jugs were manufactured on day 286 of 2014, so 47 days ago. Has been stored in the garage out of sunlight since purchase.
    Should be able to refine my numbers now that I've got the correct strength in on PoolPal. Was mostly concerned whether or not ~3 gallons a week sounded high or low or just right.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    It's gonna be what it is in the amount per week. With colder water temps and the sun angle lower in the sky you'll lose less FC per day. 😎
    Jeff
    Sep 2013
    810
    Targets "Up & Up" bleach (which is what I use) is also the same price as the Walmart brand, FWIW
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    Check out your local pool store, they may have the stronger bottles of liquid chlorine (10% and 12.5%) for a better price. I have a pool store near me (not Leslie's) that sells a 4 gallon tote of 12.5% for 17.99 plus tax, and it's always fresh and made regionally by HASA. Works out cheaper than buying regular 8.25%. Something worth looking into.
    J.R.
    20K IG gunnite pool
    2HP Hayward single speed pump
    Cartridge filter
    Sep 2013
    810
    $17.99 for 4 gallons of 12.5% comes out to .281 per Oz. The Target Up & Up bleach comes out to .275 per ounce (using Target credit/debit card). The savings of .76 per gallon is probably what it would cost me in gas to get to the pool store. I have a Super Target less than a mile from my house.
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    That is a slight bit cheaper, and I have a Target nearby as well. Though in my case I am getting the strong stuff from a local mom and pop pool store that is well run, so I don't mind supporting them and also getting the stronger chlorine at the same time.
    J.R.
    20K IG gunnite pool
    Cartridge filter
    Jul 2012
    Central Texas
    436
    HEB is 3.50 per 121 oz bottle, which works out to 2.895 cents per ounce. Given that it can be picked up at the same time as grocery shopping with no other trips needed etc., that's not an unreasonable price point when you consider time and gas. I've looked at the Leslie's web site and don't see any product that says or resembles bleach. Lots of choline tabs but no bleach. Maybe they call it something different. Lowes is 4.24 per 121 oz bottle. Target is 3.59 per 121 oz bottle.
    Jul 2012
    Central Texas
    436
    Oh...I looked at the walMart great value brand. 2.94 per bottle and not available for purchase at, or shipping to, a Walmart within 50 miles of my location. I refined my numbers and the gallons over the winter usage is closer to 50 which would save me maybe 25 bucks if that brand were even available. Great info to check out however, so thanks!
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    Both of the Leslie's that I visited before I found Glacier Pool Supply had 10% in a 4 gallon case. They don't push it like like they do the trichlor tablets, but they did have it.
    I have seen it labeled LiquiShock, or some variant of that. I think that's how they market it too, come to think of it, as a shock instead of a primary chlorine source.
    BTW, you may be overestimating your chlorine usage. Once my water temp dropped into the 60's my chlorine demand dropped dramatically. I have only been adding every other week or so to maintain 5 ppm.
    J.R.
    20K IG gunnite pool
    Cartridge filter
    Jul 2012
    Central Texas
    436
    Yes. I possibly am. I was estimating on 1.5 to 2 ppm loss per day which is what I've seen on nice sunny days. Past couple it has been 0.5 to 1 when it has been cloudy and rainy. I am still cataloging and learning the averages and the ups and downs for winter care vs. summer when SWG is in place.
    Sep 2013
    810
    Target "Up & Up" brand bleach which is 121 Oz of 8.25% should be $2.94, even in central TX. You may have been looking at the wrong price tag or the wrong item. If you have a red card (Target credit or debit card) you get 5% off making it $2.79. That's the best price I know around here right now. Occasionally they have a buy 2 get 1 half price or something like that.
    Jul 2012
    Central Texas
    436
    Good info, thanks!
    Sep 2013
    810
    I just discovered there is an additional 5% off by using the [free] "cartwheel" app. That makes Target bleach $2.65 if you have a [free] red card.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Hi again bob!
    Several pool stores sell what they call liquid shock or something similar. Lowes sells it also, as well does Home Depot, - at least where I live they do. Usually in 10 or 12.5% sodium hypochlorite.
    If you compare the MSDS of household bleach to the MSDS of liquid pool shock, you'll see the ingredients are almost identical. The MSDS will always tell the tale.
    This goes for lots and lots of pool products that go by all sorts of different names. Some very useful, some very useless.
    Quote Originally Posted by eqbob View Post
    Divin Dave,
  20. Back To Top    #20
    Quote Originally Posted by Divin Dave View Post
    Only some of the Lowe's in my area carry 10% and they store it outside, which isn't so bad this time of year, but I don't need much this time of year. I haven't found it at Home Depot yet, but I've only checked one.
    20,000 gal in-ground plaster pool with sand filter. Replastered recently. Mostly adding bleach and acid. CYA was high when I took over.
