Thread: New Pool Owner from Pennsylvania
    Hi everyone! My name is John and I'm from Northeast Pennsylvania. I recently moved into a new home with an 18x36 in-ground pool and I am glad that TFP.com exists because I was clueless as to how to take care of this pool. The guy that sold me this house said "the chemicals are in the garage, just read the labels." Sure, don't I wish it was that easy!
    Again, I've really learned a lot from this site so far and I'll be sure to visit often. Thanks!
    18x36 25000 Gallon In-Ground Pool
    Vinyl Liner
    Hayward DE-3600 Filter
    Hayward Automatic Chlorinator
    1 Skimmer, 3 Return Jets
    Butterfly's Avatar
    South Carolina
    10,045
    Re: New Pool Owner from Pennsylvania
    Hi John and welcome to the forum!
    You're done SLAMing when:
    welcome to TFP!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    99ways2die's Avatar
    May 2008
    Central NJ
    44
    Ha!
    At least you had someone to tell you where the chems/etc is...when we bought our house a few months ago all I got was a set of keys.
    ..............took me 2 days to figure out how to turnt he light on in the pool.
    (why, it's a great idea to put a timer box in the garage (nowhere near the pool or fuse panel), hide it behind some boards, and have the switch for the pool light connected to it).
    Good luck with our new place and the pool.
    -99
    30K gal, in-ground/vinyl, S-270T filter, 1HP pump, H-300 gas heater, Liquidator,Blue Diamond robot, Poolskim
