Thread: Hayward Goldline SWG replacement.
    iggy's Avatar
    Jan 2008
    The Cool Part of Arizona
    175
    I have had my Gold Line SWG system installed in my new pool in 2008.
    It was with a T-15 Cell and my inground pool is only 11,000 gallons.
    Now being in Arizona and all the heat and sun I can see why maybe I needed a T-15 cell which produces more Chlorine.
    Now my questions relates to the T5, T9 and T15 Cells. They actually look like the same cell but marked differently for pool gallon size.
    As you can see the T3 has only 7 plates and understandably produces less chlorine but what about the others?
    Are they the same cells? Their is a price difference between them online.
    Can anyone explain?
    T-3 says for 15,000 gallon pools and produces MAX .4 lbs of chlorine a day, (7 plates)
    T-5 says for 20,000 gallon pools and produces MAX 1.45 lbs of chlorine a day (13 plates )
    T-9 says for 25,000 gallon pools and produces MAX 1.45 lbs of chlorine a day (13 plates)
    T15 says for 40,000 gallon pools and produces MAX 1.45 lbs of chlorine a day (13 plates)
    Thanks
    In-Ground SWG pool 11,000 gal., Jandy CL460 Filter, 1.5hp Stealth Jandy pump, Paramount PV3 In-Floor cleaning sys., Goldline SWG, Hayward Color Logic 2.5 LED Light
    38,251
    Re: Hayward Goldline SWG replacement.
    I think found bad data. The T5 is an older model which was replaced by the T15, so those may match. Likely the T 9 data is wrong.
    Having a larger cell means you may not have to run the pump as much to maintain adequate FC levels. The T9 should be enough for you. But, older SWG systems only work with the 5 and 15 cells, I am not sure when the software switched.
    Are you able to set the cell size?
    iggy's Avatar
    Jan 2008
    175
    I thought so also that the larger number cell would put out more and have to work less but data shows the number of plates and size are identical.
    So are you saying that they only have a T-3 and T-15 cells now?
    I have a true Goldline product with software version 1.40
    With version 1.4 software you can only use the T-15 cell. You need version 1.5 to use the other cells.
    Your chlorine production numbers are also wrong for the T-3 and T-9. The T-3 is 0.53 lbs/day, while the T-9 is 0.98 lbs/day. The T-5 is no longer made.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    The most economical one is the largest one. It will last longer and is capable of putting out chlorine at a faster rate. You can always turn it down if needed.
    chiefwej
