Results 1 to 10 of 10
Thread: FC tripled in one day
    May 2014
    Dallas, Tx
    72
    Good morning. Been trouble free since April and have never enjoyed our pool more than this year. Thanks to all who helped in the transition. Yesterday my readings were:
    FC - 4.0
    CC - 0
    PH - 7.7
    TA - 50
    CYA - 40
    CH - 350
    I added one gallon of 8.25 bleach which is what I have been adding approx 3 times a week since the weather got colder.
    This morning the readings are:
    FC - 14.5
    CC - 0
    PH - 7.8
    TA - 50
    CYA -40
    CH - 350 I tested the FC 3 times and got the same readings. It is about 45 degrees here this morning. We keep our pool open and running year round. Using the same chemicals and leaving CYA for last based on some
    cold water info I have read on here. The water is beautiful. Any idea what might have happened and what I should do? Appreciate your help.
    Mike
    Pool is inground 20' x 40' 42000 gallon, rectangular plaster about 60 years old, replastered 2 years ago. Pentair VS Intelliflo pump, Pentair 420 Clean & Clear Plus Cartridge filter. Using K-2006 test kit.
    Jun 2011
    Long Beach, CA
    2,790
    Re: FC tripled in one day
    Just let the chlorine come down on its own, you will not have to add any for a little while.
    My best guess is that the first test was not accurate for some reason and now the FC is a little high.
    30,431
    1 gallon of 8.25% would've raised your FC by 2.0 ppm. There is no way to get more unless you add it.
    I suspect you had a math error as ping suggests.
    Are you using PoolMath?
    swoopman's Avatar
    Jul 2014
    Annapolis, MD
    213
    Is it possible that the container you used to pull your water sample had any residual chlorine in it or that the water was not properly circulated before pulling the sample?
    TF-100 Test Kit
    22,000 gallon, 20x40 kidney-shape IG plaster pool built in 1986
    Nautilus NS-36 DE filter, Hayward Self Prime Super Pump 1HP
    Polaris Automatic Pool Cleaner, PB4-60 3/4 HP pump
    If you accidentally used a 25 ml sample for the most recent test, that would mean that your actual fc is 5.8, which is close to the expected level based on the starting fc, pool volume, and amount of bleach added.
    If you have tabs in a feeder or skimmer or a swg or a peristaltic pump adding chlorine, then that could explain the discrepancy.
    Support the site
    May 2014
    Dallas, Tx
    72
    Good morning. It appears that JamesW was correct. I must have used a 25 ml sample because this morning, my readings are back to normal. The embarrassing part is that I did the test 3 times and must have used the wrong sample size 3 times. My apologies for wasting everyones time and thank you for the support.
    Mike
    Citizen's Avatar
    Oct 2014
    Orlando, FL
    92
    lol, it happens to the best of us. Don't take it too hard.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,050
    Quote Originally Posted by mbeck5 View Post
    Just wait until you add the wrong reagent to one of the other tests and wonder why it won't change colors even after dumping half a bottle of the third reagent in...
    May 2014
    Dallas, Tx
    72
    You are all very kind. Thanks again and best wishes for a great Thanksgiving.
    Mike
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,006
    Man.... dont worry! We have all been there. LOL! We can laugh with you and not at you!
    I'm glad you've enjoyed your pool more than ever before. This TFP isn't so bad is it?
    Happy Thanksgiving
    Divin Dave,
