Thread: No PH or TA adjustment for almost 2 years
    East_Akl_Neil's Avatar
    Apr 2012
    Auckland, New Zealand
    70
    Hi All
    Im getting my pool up and running again for our new season so still adjusting the water. However looking at the numbers the PH and TA are the same as they were 12 months ago when Inopened up the pool, and how I left them at the end of the season. Question is shoud I be worried and adjust the levels, or should I leave well alone and say that is the ideal level for my pool and keep them in that range.
    I have taken the water to a couple of pool stores, and also got new reagents for my test kit and the numbers are always similar to each other.
    FC:1.5
    CC:0
    PH:7.2
    TA:40
    CH:50 (Ignoring this with a vinyl liner)
    CYA:20 (Working on this)
    Temp:20
    Im not sure if it has anything to do with the way that I close the pool for winter, or Im doing something wrong in testing but with pool stores giving same/similar readings cant see that as being the issue. I close the pool by backwashing the filter, the turning the pump timer off and letting the pool do what it wants untill next season. Even then the water stays clear, just gets a think layer of alge on the bottom.
    Whats your guys thoughts.
    Neil
    Late 1970's 39000L IG Concrete Pool with Vinyl Liner
    Austral FT55 Sand filter
    Hurlcon E170 Pump Brochure,Manual
    32-40mm Pipe work
    Living in beautiful New Zealand
    30,431
    Re: No PH or TA adjustment for almost 2 years
    Well, if your pool has been stable for two years, I sure wouldn't adjust anything about pH and TA. You could bring both up to around 7.5 and 80 TA but you are generally within the guidelines we suggest and are having no problems, right??
    Don't fix it if it ain't broke.
    You CYA should be raised to 40 ppm. How are you "working" on it?
    There is certainly nothing to worry about. Personally, I would raise the TA to 50 or 60, which will eventually drive the PH up just a little. But there is no rush on doing that.
    I haven't had to adjust my PH in several years.
    Apr 2012
    70
    Duraleigh, im added in some cya powder a week ago and have been waiting for it to mix before testing, and now adding in a bit more to bring it up to about 40.
    JasonLoin, thanks for the feedback, ill raise the ta a few points and leave it there.
    Neil
    32-40mm Pipe work
