Thread: Weather conditions for re-plaster?
    Oct 2014
    Bay Area, California
    146
    In January I am moving into a house that may need a pool re-plaster. I figured I might as well get it re-plastered as soon as I can but I have some concerns about the weather. Obviously I don't want it to be raining, but I am concerned about the temperature/humidity etc.
    I am located in the San Jose California so would probably be somewhere in the 40-60 degree range throughout the day/night. I couldn't really find any information about the ideal temps but I want to make sure the re-plaster could not be compromised by the weather conditions.
    Oct 2014
    Sacramento, CA
    72
    Re: Weather conditions for re-plaster?
    Your plaster company will be able to schedule for these conditions they will not plaster on days they think it may damage there work
    David Randolph
    Warranty Station
    Pentair
    Jandy
    Owner Sac Pool Pros
    Warmer is better, but above freezing is alright. No rain for a minimum of an hour after plastering is complete, and preferably longer. Somewhere below 50 ,the plaster may need to be covered to keep it warm for a while after it is applied, though that varies depending on conditions and the mix used. Humidity isn't really an issue either way.
    As SacPoolPros said, the plaster crew should be totally familiar with the conditions in your area and reschedule as needed. The only things that might cause serious issues are unexpected freezing temperatures or unexpected sudden rain.
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Great plaster info from industry experts....one of which is on this forum as well.
    http://www.poolhelp.com/onbalance.aspx
    I'm posting this, as I imagine you have more plaster questions...
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
