Thread: Almost there....
    Jul 2012
    Central Texas
    436
    Almost there....
    After dumping several tons of water due to salinity, and adding in new' I've almost got things back in balance.
    ph 7.6
    TA 70
    CYA 70 ( or should be since it was 30 and I just added 128 ounces)
    TC 8.5
    CC 0.0
    CH 280
    Salt 3000
    CH could use a bit more work. Salt could go a hair higher, but will wait for it to go down more from rain.
    Went through several acid / aerate cycles to get TA down from 220 so that took several days. 1 gallon repeatedly dumped TA 40, so that was a good metric to learn for my pool.
    Feeling like it's almost there.....
    Central TX / 12K GAL / IG / SWG / DE filter / Pentair SVRS & 3 swim jet pumps / Spa bench and jets / Single body of water / No heater.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Re: Almost there....
    All I'd say you need is to turn down that SWG a notch.
    Jul 2012
    Central Texas
    436
    I kicked it that high with bleach this morning because the salt cell is mostly off and I hadn't put the cyanuric in yet. And it was really bright night bright sunny....probably sunniest day in 3 weeks.
