Results 1 to 9 of 9
Thread: Booster Pump Replacement
    Hi All,
    I think it's time to replace my Pentair LA01N. It's making this horrible, high pitched noise. I've already replaced the bearings.
    In searching the forums, there are a lot of recommendations for replacing the motor, but at $171 it seems to make more sense to spend the extra $50 for a brand new pump.
    Am I missing something? Anything else I should look at before biting the bullet?
    Lynn
    12000 Gallon Freeform Pool
    SWG
    Jandy AquaPure 1400
    Leslie's DPD Complete Chlorine Kit + FAS/DPD Chlorine Tester and Swirler from TFP.com
    Tree covered lot - cottonwoods and crepe myrtles. Great shade during the summer, miserable fall cleaning leaves from the pool.
    Sep 2013
    Dallas-Ft. Worth Metroplex, TX
    810
    Re: Booster Pump Replacement
    If you're handy enough to replace the motor yourself, why not save the $50?
    14K Freeform Gunite w/60% Blue Quartz plaster, Quad DE filter, Intelliflo VS Pump + Booster for Cleaner, Aquacal Heat Pump
    The pump is 6+ years old so it's got rusted screws on the cover where the wires go in and the plastic housing on the back is cracked. I don't want to spend extra money, but at some point I would think getting a new pump that has a warranty makes the most sense.
    SWG
    Jandy AquaPure 1400
    Sep 2013
    810
    It would be hard to disagree with that.
    Oct 2014
    Sacramento, CA
    72
    I would never replace the motor on a booster pump honestly it cost like you said 50.00 more to buy a brand new one with a warranty i don't even replace seals on them when they start leaking i just replace them its easier since they are so cheap... the waterway booster is only 210.00
    David Randolph
    Warranty Station
    Pentair
    Jandy
    Owner Sac Pool Pros
    Thanks for the tip on the Waterway. Is a pump, just a pump? Meaning, as long as it's the same HP and it runs on the voltage I have, are they all interchangeable?
    The Waterway I found is the Waterway Booster Pump 3810430. I'm not seeing it for $210 anywhere.
    SWG
    Jandy AquaPure 1400
    Sep 2013
    810
    It's just a device to push water through a pipe. Unless it's hooked up to automation I don't see any reason to stick with a specific brand.
    Oct 2014
    Sacramento, CA
    72
    PM me and ill send you link of were i found it for 210 if your still looking for it i found it on google shopping
    David Randolph
    Warranty Station
    Pentair
    Jandy
    Owner Sac Pool Pros
    Quote Originally Posted by SacPoolPros View Post
    Sigh. I recently replaced a cracked volute on my PB4-60, then the o-ring, then it was still leaking near the main seal, so I replaced that and the back plate cracked when I tapped it in. So, I just ordered a full replacement, which as you say, is what I should have done from the start given how inexpensive it is. After I ordered it, I noticed the motor was 15 years old! Hopefully my new one will last that long.
    20,000 gal in-ground plaster pool with sand filter. Replastered recently. Mostly adding bleach and acid. CYA was high when I took over.
