Thread: Help with new pool acid wash???
    Nov 2014
    Baton Rouge
    1
    Question Help with new pool acid wash???
    Great site, I have been reading for a while and would like to ask for some help from the seasoned owners.
    We put in a new gunite pool last spring with diamond brite plaster. Our installer advised us to brush frequently which I did over the course of several months. A couple of months after the install was complete the plaster began to scale up quickly with what I assume is calcium. The installer did not have an answer and claimed he had never seen this before. Now the pool is practically 100% covered with the calcium scale, and the installer has committed to acid washing to remove the scale. My concern is that he does not seem to be educated in what caused the original issue and it may repeat. Any advice on where to look or whom I may contact to learn more about this myself so I can ensure this will not happen again?
    Thanks in advance
    B. Robinson
    Age of Pool - less than 1 year
    System Type: Colored Plaster
    Volume 18,000.00
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,025
    Re: Help with new pool acid wash???
    Im not a plaster or pebble expert, but scaling can be caused by incorrect chemical balance in the water. A contributing factor can also be the % of calcium chloride in the plaster or pebble mix. Preferably there should not be any at all in it. However, if the concentration of Calcium Chloride is about about 1.5%.
    The best starting place for you to learn more about pool chemistry, is to click on the POOL SCHOOL button at the top right of this page.
    Start with the ABC's of pool chemistry, this will get your feet wet, so to speak.
    The next thing you should do is to get your own test kit so you will know what your water chemistry is. You will need to test it regularly in order to keep it in good shape.
    Most everyone here recommends the TF100 test kit. Its only available on line. It is the best test kit on the market bar none and is WAY more accurate than the pool store testing. www.tftestkits.net
    Without anyone knowing the chemistry of your water, by means of you posting all of the water parameter test results, its pretty much an impossibility to make a recommendation.
    It would also be helpful to add some details about your pool to your signature. Knowing the size, the type of pool you have, the finish, the circulation equipment all are very useful in trying to help ya out.
    Divin Dave,
    Oct 2014
    Sacramento, CA
    72
    What type of scale is it like white raised flakes coming through the pool plaster?
    David Randolph
    Warranty Station
    Pentair
    Jandy
    Owner Sac Pool Pros
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    http://www.poolhelp.com/onbalance.aspx
    Do you happen to have a full set of reliable test results?
    my bet is your pH is insanely high.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
