Thread: Sulfamic acid
    Sulfamic acid
    Some references say that sulfamic acid is used as a chlorine stabilizer. It looks like Jack's Magic # 2 is mostly sulfamic acid. That would indicate that it can be used for copper and scale as well.
    Does anyone know about it's use in pools or water treatment in general.?
    Support the site
    Re: Sulfamic acid
    One of it's more common uses is as an acidic cleaning agent, often used to remove scaling from industrial equipment. It is safer than the regular acids when used around chlorine because it does not cause the formation of chlorine gas when mixed with common chlorine compounds, which all of the other common acids will do.
    I haven't heard of anything about it being a chlorine stabilizer.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Sulfamic acid
    From a quick Google search I found the papers
    STUDIES ON THE ROLE OF SULFAMIC ACID AS A DESCALANT IN DESALINATION PLANTS
    and
    STUDY THE PERFORMANCE OF SULFAMIC ACID AND CITRIC ACID IN REMOVAL THE SCALE DEPOSITED ON THE DURA REFINERY HEAT EXCHANGE PIPING SYSTEM
    This paper talks about sulfamic acid reacting with chlorine to form chlorosulfamic acid and how sulfamic acid was an effective hypochlorous acid scavenger when used in bleach pulping that used chlorine dioxide. The question is what is the equilibrium constant for chlorosulfamic acid vs. hypochlorous acid. Also, what is the disinfection and algae inhibition capability of chlorosulfamic acid?
    Re: Sulfamic acid
    Some references say that sulfamic acid forms N-chloro sulfamates. In any case, I can't find any references that show sulfamic acid actually being used in swimming pools as a chlorine stabilizer.
    Support the site
    Jul 2011
    Arizona & California
    805
    Re: Sulfamic acid
    According to the "Handbook of Chlorination" by Clifford White, Sulfamic Acid was used a short time around 1956.
    But it was found not to be very effective and discontinued.
