Page 1 of 4 1234 LastLast
Results 1 to 20 of 68
Thread: New pool in Southern, CA
    Oct 2014
    Tujunga, CA
    109
    Hi guys,
    Here are some pictures of my pool build. Tomorrow they will be pouring the concrete for the retaining wall.
    Jun 2014
    Sanger, TX
    555
    Re: New pool in Southern, CA
    Wow! You and Corelone with the hills. Is the flat section that is walled in (where the pool is going) - the only flat open section on your property? You probably have some amazing views - but also the challenges of living hillside. -Karen
    New in 2017, will update
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,465
    What Karen said! views and challenges for sure!
    Thanks for sharing your build with us. Keep the pics coming.
    Kim
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    But on the plus side.....no nosy back yard neighbors to contend with!
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    Apr 2014
    NE Texas
    327
    Man, those hills! I'm sure they already have plans but just make sure they waterproof behind that wall and get some drainage behind there.
    Looking forward to watching this one. That hill is so close and high you could almost build a platform on it to jump off of into the pool!
    Done! Pool build thread here
    38 x 18 free form, IG gunite with all gunite waterfall/slide/grotto
    18" raised spa, waterfall into pool
    Hayward 3hp Tri Star Pump x 3, 525sqft Swimclear filter, Polaris 280 cleaner
    Hayward LED pool lights, Hayward LED accent lights, 400K BTU Heater
    Jun 2014
    Sanger, TX
    555
    Jumping off the wall into the pool - now that's good thinking! My dad was a general contractor - when he dug our pool as a kid, he made the depth 10'. My brother and I first started jumping off the top of the slide into the water, then we started climbing onto the roof of the house and jumping in....of course that was in the 70's and we didn't have pool alarms either. Sometimes, I wonder how we survived our childhoods! Your pool looks nice and deep -Karen
    Oct 2014
    Tujunga, CA
    109
    Hi guys,
    Thanks for the positive comments. To answer some questions. Yes, that was the only flat part of my backyard, until we cut away the hillside. We had a nice surprise when we started the project, I did a survey to see my property line and it turns out my property is 20 feet behind that retaining wall, where you see the pool equipment pipes. The original plan was to go into the hillside 5 feet more, but we saved alot of digging by going straight back. That retaining wall is going to come down and my new fence line will be straight back 20 more feet, so it opened up a big area for us. Twolabs, yup a nice draining system and waterproofing materials are going to be installed. You guys got it right, no nosy nieghbors! The views are good, we are not that high up but have a free fireworks show every July 4th.
    We almost had a scare during the digging, the diggers were claiming I was on bedrock, they couldn't dig, etc, etc. Mind you my access is narrow, so they barely got a bobcat in. So we had a meeting with my contractor, my dad who's a civil engineer was there and told the bobcat operator "just push your bobcats pedal down and dig!." Haha, he did it and broke thru. We had to soak the dirt a day or two but everything turned out great in the end and they ended up digging deeper than we had planned on so it worked out good!
    We should supposedly be done in a month, I'll keep up on updating. Thanks guys!
    Oct 2014
    Tujunga, CA
    109
    Retaining wall started:
    Oct 2014
    Tujunga, CA
    109
    Update: Retaining wall completed. Coping going in. Grading, patio, pool equipment area all being worked on to prep for concrete maybe on Saturday.
    Jul 2012
    Tallahassee, FL
    30,465
    That is a lot of wall! Glad I did not have to do it!
    Is there some kind of drain or something to help the water drain from behind the wall?
    Kim
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    I'm a fan of brick...I love your coping choice!
    Oct 2014
    Tujunga, CA
    109
    Quote Originally Posted by kimkats View Post
    Kim
    Yup, there is a concrete channel going to be built that will empty into a catch basin. The drain is sloped to the rear of the yard.
    Quote Originally Posted by JayBauman View Post
    Thanks! We have brick work in the concrete of the patio, so we wanted to match it. I will also have brick in the steps that will be built around the patio.
    Oct 2014
    Tujunga, CA
    109
    Not much of an update, the 2 steps were finally done plus drains were installed. Looks like coping is almost done now, just taking over a week.
    Jun 2014
    Sanger, TX
    555
    Every step is progress! The brick is really looking good. - Karen
    Jul 2012
    Tallahassee, FL
    30,465
    every brick done is good progress!
    What did a fellow pool builder say?
    Fast, cheap, good-pick one I say pick good!
    Kim
    Oct 2014
    Tujunga, CA
    109
    Fence around property going in:
    Wiring for lights on top of wall done, grout work on coping almost done:
    Skimmer was too low so they raised it:
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,817
    Yeah skimmer prolly wouldn't work too well like that. Coping looks great. No mudslides in your parts hopefully?
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Oct 2014
    Tujunga, CA
    109
    Nope, no mudslides!
    Biggbotti's Avatar
    Nov 2014
    Ny
    112
    Looking good
    34x48 40,000 gal mt lake concrete wall vinyl lined pool,gli 28 mil blk granite liner w/sure-step, pentair easy touch 8 w/screen logic,pentair fnsp 48 filter,2 pentair intellichlor vs pumps, pentair intellichlor ic60, 3 pentair led intellibrate 5g lights, 4 pentair magic stream Laminars, 12 ton moss rock waterfall
  20. Back To Top    #20
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    Quote Originally Posted by emil View Post
    At least they caught it before the water was in the pool!
