Thread: Maximum safe chlorine level
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    What is the maximum chlorine level you could have and still be safe to swim?
    Thanks
    My pool is a 10,500 gallon (420 Sq Ft ) kidney shape. STA-RITE HRPB30, Sand filter 30" 98 GPM, 1 HP Maxi-Glas 2 pump, BBB Method, Taylor K-2005 test kit, 50 Watt 12V low-voltage pond light illuminates the pool at night for a nice soft glow.
    Dec 2007
    Central New York
    504
    Re: Maximum safe chlorine level
    Quote Originally Posted by meatloaf
    Thanks
    Asking that is like asking how high is high. Everyone has an different opinion.
    I use 10ppm as a guide line. If the level was 11ppm and a hot day, I would still let the grandkids go in. I would just tell my wife to make them take a shower when they were done swimming. To know when enough is enough, I would watch their eyes for redness.
    I hope this gives you alittle help.
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    It all depends on your CYA level. Higher CYA levels allow higher FC levels.
    I will swim up to shock level for my CYA level. Some people are willing to go higher.
    ivyleager's Avatar
    Sep 2007
    Raleigh-Durham,NC
    489
    I think I've jumped in at 13ppm, CYA was 100. I made sure to wash suits immediately, as well as myself!
    Another way to look at it: have you ever jumped into a pond? That had no chlorination, and most likely quite a few yuck molecules swimming around with you.
    CaryB
    36 x 18 IG vinyl, 25K, 1 HP pump, sand filter
    1 skimmer, 2 returns, no main drain
    Old school: PoolSolutions test kit
