Thread: SWG and Chlorine
    SWG and Chlorine
    HI All,
    Just wondering for my memory bank, if someone with an SWG is having an issue with the water, can you add chlorine so supplement or do they need to do something else because of the SWG? Purely hypothetical, just a question in my mind
    Thanks
    24' Round 54" Impulse Ovation AGP, 1.5 HP 2 Spd, 150 Sq Ft. Cartridge Filter, RayPak 130K BTU NG Heater, BBB in full effect!!
    Vist TFT Test Kits --- Visit Pool School ---
    Visit the Pool Calculator
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Re: SWG and Chlorine
    you can add FC by other means (bleach as example)
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    38,520
    In fact, it is recommended to supplement the FC using bleach if needed. Like if you have a planned high use event, good to bump up the FC with bleach before and/or after. A SWG is very slow at adding chlorine.
    And certainly if you end up with algae, you should use bleach to follow the SLAM process ... usually with the SWG turned off.
