Results 1 to 9 of 9
Thread: Help running pool year round
    Split by moderator from HERE. Please start your own topic for your own questions and do not hijack another members thread. Thanks, jblizzle
    where on this forum do I go to ready about the process of keeping an inground pool open during the winter (all year)? I'm in NC and still haven't closed yet and it got down to 22 degrees last night.....i put a pool cover over the pool pump and stuff and ran the pump all night. Not closing in NC a good or bad idea? It would cost me $180 to have someone come and close my pool so if I could just maintain it myself over winter I would like to do so. Even though its winter I enjoy seeing the pool water out of all my windows and not a cover.
    Greenville NC
    14,657 gallons IG vinyl pool 14x28
    1HP A.O. Smith Pump Polaris 9550 sport robotic cleaner
    Pentair Tagelus high rate sand filter 04C TA-60/60D
    38,521
    Re: Help running pool year round
    Sounds like you are doing what you should. If the temp drops below freezing overnight:
    - A cover over the equipment and even a light bulb under the tarp to add warmth.
    - Running the pump at least a few hours overnight.
    If you happen to lose power and the temperature is going to be below freezing for more than a few hours overnight, then you should drain the equipment at the pad to prevent damage.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,013
    I would expect that maintaining a pool during winter will be similar to what we do in Texas. No need to lower teh water and properly close it. Just some basic maintenance is all thats needed.
    Jason (jblizzle) is right about what to do for the freezing nights.
    As far as the water chemistry goes, just make sure you maintain your FC as you normally would, and your PH, you will be just fine.
    Quote Originally Posted by Matthewmon View Post
    Divin Dave,
    how important is the light bulb??? I'm afraid of it starting a fire somehow...which i do not want to risk... thanks!
    Greenville NC
    38,521
    Depends on how cold it gets
    mas985's Avatar
    Pleasanton, CA
    11,742
    The cover alone can help quite a bit. The risk depends on the smallest size of your plumbing, lowest temperature and duration of freezing temperatures. But with 22F lowest temps and a cover, you are good for at most 13 hours with 3/4" pipe even without the pump running. Running the pump adds safety.
    If you are interested in reading about freezing and risks, I started a thread on the subject here: http://www.troublefreepool.com/threa...eze-Protection
    We have gotten down to 22F before and I didn't run the pump at all and didn't even cover the equipment but my smallest pipe is 2" so there is some margin for that.
    Mark
    Sep 2016
    Arkansas
    437
    I saw somewhere suggestions of a 200 watt incandescent bulb under a tarp to protect equipment on pad from freezing during lower temperatures. Can anyone recommend a good fixture to put a 200W bulb in under the tarp?
    I don't have any old lamps or work lights with this wattage rating and want to prepare before winter.
    17'x35' 22,500 gal. Gunite IGP 3.5-8.0 ft. IC60 SWG, 2 skimmers, 2 main drains, 4 returns. CCP520 cartridge filter, 3hp IntelliFlo 2 VST VSP, EasyTouch 4, ScreenLogic2, 2 IntelliBrite Color LEDs, Poolmiser autofill, UltraTemp 120R H/C 125K BTU heat pump, Diamond Brite Super Blue, No spa or water features.
    38,521
    There is nothing specific about needing 200w. Any bulb will be a source of heat.
    Jul 2015
    Central Valley CA
    1,109
    200 watt sounds like overkill depending on the size of your equipment pad. I don’t use a bulb to warm my equipment but in my beer brewing there are times I am growing yeast in my garage that gets down to 50F. I am able to keep a large cabinet that is approx. 30 cu ft. at 72F with a single 60 watt bulb and a thermostat. Granted the cabinet is not subject to wind chill but I still think it would be plenty of heat for those that can get by without having to close, smaller fire danger too. Any outdoor light fixture should serve.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
