Thread: Gauge reading 5, normally 25-28
    Nov 2014
    harrisburg NC
    35
    Last night it was 15 degrees, and ran my filter all night. this morning the gauge was reading 5 normally it runs 25-28. Any thoughts as to why? Can those gauges freeze? Everything seems to be working just fine in the pool, including the attached spa.
    20,000 gallon concrete roman style Inground pool (build date 8/13)
    Pent air FNS60 DE filter (using Jacks filter fiber stuff)
    Raised Spa/Hot tub and Polaris 360 cleaner (named Vincent ;-))
    RayPak pool heater 406a
    TF100 test kit
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Gauge reading 5, normally 25-28
    Yes the gauges can freeze and yes they do fail and quite often. Let it warm up during the day and see if changes. If not, replace it. The oil filled gauges are little bit more resistant to problems so you might go with that instead. See tftestkits.net.
    Mark
    Nov 2014
    harrisburg NC
    35
    just had the wife look at it again and its up to 28(ish). All is fine now, i can breath easy again. 15 degrees in NC! I need to pack up my pool and head south!
    TF100 test kit
