Thread: Chemical math formula for borates (boron)
    Jun 2013
    East TN
    309
    What is the "chemical" formula for figuring ppm for borates as far as a chemistry perspecitve?
    I understand they are equivalent or measured in borons, such as on a test strip but I cant figure out where the numbers are coming from.
    Here is an example (calcium hardness) of what Im looking for which shows where the numbers are coming from:
    Calcium Carbonate (CaCO3) = 100.0869 g/mol
    Calcium Chloride (CaCl) = 110.98 g/mol
    100.0869 / 110.98 = 0.901846278608
    (CaCO3gmol / CaClgmol = 100% Calcium Chloride Product is 90.18% Calcium Carbonate)
    0.901846278608 x 0.95 = 0.85675396
    (answer from above x 95% Calcium Chloride Product = 85.67% Calcium Carbonate)
    8.3333333333333333 / 0.85675396 = 9.7266353 LBS to raise CH 1ppm per 1,000,000 gallons (for 95% product)
    (weight of water in lbs / answer from above = LBS to raise CH 1ppm per 1,000 gallons (for 95% product))
    This information fits into a similar equation somehow:
    Boron
    Sodium Tetraborate Decahydrate (Molar Mass: 381.38 g/mol)
    Sodium Tetraborate Pentahydrate (Molar Mass: 291.29 g/mol)
    Boric Acid (Molar Mass: 61.83 g/mol)
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
    Re: Chemical math formula for borates (boron)
    Borate is measured in ppm of Boron. You also need to remember that Sodium Tetraborate contains more than one boron.
    Jun 2013
    East TN
    309
    I didnt think of that.
    Sodium Tetraborate Decahydrate: Na2B4O710H2O
    Sodium Tetraborate Pentahydrate: Na2B4O75H2O
    Boric Acid: H3BO3
    Sodium Tetraborates contain 4 borons while Boric Acid only conatains 1.
    Boron has a molar mass of 10.811 g/mol.
    So in the case of Boric Acid, it is 17% boron by weight (for a 100% boric acid product).
    10.811 / 61.83 = 0.17485
    8.3333333333333333 / 0.17485 = 47.6598 LBS to raise Borates 1ppm per 1,000,000 gallons (for 100% product)
    That looks right to me, is it?
    I'll have to come back later to try to calculate the other two which look more difficult.
    That looks right, and matches Pool Math (given the rounding it does).
    Jun 2013
    East TN
    309
    I calculated STD like this which also matches. It wasnt any harder than the other one.
    Sodium Tetraborate Decahydrate (has 4 borons)
    4 x 10.811 = 43.244 (4 Borons are 43.244 g/mol)
    43.244 / 381.38 = 0.1133882217211 ( 100% STD Product is 11% boron by weight )
    8.3333333333333333 / 0.1133882217211 = 73.49381 LBS to raise Borates 1ppm per 1,000,000 gallons (for 100% Product)
    Sodium Tetraborate Pentahydrate would be the same formula but enter STP's g/mol instead of STD.
    Thanks Jason. Sometimes you need a push in the right direction.
